Force exerted by the floor on the feet of a student doing pushups
  • Thread starter Thread starter PhysicsPhun
    Force Student
In a physics problem involving a student doing pushups, the force exerted by the floor on her feet is calculated using torque and equilibrium principles. The student has a mass of 45.0 kg, with her center of mass positioned 1.01 m from her feet and 0.65 m from her hands. By treating her body as a plank with her hands as the pivot point, the normal force at her feet can be determined using the formula that equates the weight times the distance from the pivot to the force times the distance from the pivot to the feet. The calculations yield a force of approximately 172.68 N exerted by the floor on her feet. This method effectively simplifies the problem and provides the correct answer.
PhysicsPhun
A physics student is about to do a pushup. Her center of mass lies above a point on the floor which is d1 = 1.01 m from her feet and d2 = 0.65 m from her hands. If her mass is 45.0 kg, what is the magnitude of the force exerted by the floor on her feet? (Neglect friction in this problem)
I don't think i know where to put the pivot in this problem. I tried a few times at the center of gravity.
Also I don't know what the "mass" of her feet are is it just (1.01/1.66)*45?
That's what i did then, once i just tried to find the Normal force with just that.
The next time I tried , I used the same method with the "mass" of her feet and hands, and then tried to find the torques. Her feet had a larger torque, so I subtracted the torque of her hands, and then divided by 1.01 to try and find the Normal force against her feet.. That didn't work either..
Anyone have a better approach?
Just treat her like a plank of wood with two supports: feet and hands. Each support will have a normal force pushing up to counter her weight pulling down (at her center of mass). For equilibrium, the sum of the torques must equal zero. You can solve it in one step if you choose her hands as your pivot point.
So, Hands are Pivot.
Weight of girl*distance from pivot = F* distance of feet from pivot
45*9.8*.65 = (1.66)F
F=286.65/1.66
F of feet = 172.68
Only one shot left for right answer.. Does that look good?
Yay: )
I got it Thanks!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
