Force given velocity as function of space.
The problem involves finding the force F(x) for a particle of mass m with velocity defined as v(x) = ax^-n, where v(0) = 0 at t = 0. The relationship between force and acceleration is given by F = ma = m dv/dt. Since velocity is expressed as a function of space rather than time, direct differentiation to find acceleration is not possible. The chain rule of differentiation is suggested as a necessary approach to relate the variables correctly. Understanding whether "a" represents acceleration or a constant is also crucial for solving the problem.
deblimp
The speed of a particle of mass m varies with space as v(x) =ax^-n
v(x=0)=0 at t=0.
Find F(x).
F=ma=m dv/dt
I am not really sure where to start from. Would x(t) or f(t) be relevant?
You have Newton's law defining the relationship between the force and the acceleration. You also have the velocity as a function of time. Now you need the acceleration. And you can plug that in for the force.
No we do not have velocity as a function of time, we have it as a function of space. Therefore we can't just differentiate and get the accel.
Usually, these problems make use of the chain rule of differentiation.
Is "a" acceleration or just a constant in the equation?
v(x=0)=0 at t=0.
Find F(x).
F=ma=m dv/dt
Try rearranging dv/dt
