Force measurement from accelorometer in Soccer ball
To calculate the impact force of a soccer ball using a 3-axis accelerometer, the frequency of oscillations is not directly proportional to the force, as it is influenced by the mass of the accelerometer and the elasticity of the rubber bands. Instead, the amplitudes of the oscillations, particularly the first amplitude, may provide valuable data for force calculation. Calibration of the device is essential to ensure accurate measurements. Understanding the relationship between oscillation characteristics and force will be crucial for effective analysis. Accurate force measurement can enhance insights into the dynamics of soccer ball impacts.
Nathaniel01
I have a 3-axis accelerometer suspended on rubber bands inside a soccer ball and am wondering how to calculate the impact force of the ball with it. I have an intuition that the force will be proportional to the frequency of the oscillations of the sensor after a collision but I am having difficulty figuring out anything more specific.
Thanks for any help in advance.
No. The frequency is determined solely by the mass of the accelerometer and the elasticity of the rubber bands.
Ok, any idea how to calculate the force then? Thanks
The amplitudes of the oscillations may give something useful, especially the first amplitude. You need to calibrate your device, though.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
