How Much Force is Needed to Hold a Hose Emitting Water at 20 m/s?
  • Thread starter Priyadarshini
  • Tags
    force
In summary: I think I see what you're getting at.In summary, a person needs to apply a force of 0.5N to keep the hose from moving backwards.
Priyadarshini
191
Water is pumped through a hose-pipe at a rate of 90 kg per minute. It emerges from the hose-pipe horizontally with a speed of 20 m/s.What is the force is required from a person holding the hose-pipe to prevent it moving backwards?
F=ma--?
Ft=mv-mu
90kg/min=0.025kg/s
This is m/t
So if we assume u=0m/s
Then, F= 0.025 x 20 (using Ft=mv-mu)
F= 0.5N
The answer is 30N
Can we assume that u is 0m/s?
F=ma--?
Ft=mv-mu
90kg/min=0.025kg/s
{You might want to check this calculation again!}
Oh!
Even then,
90kg/min=0.0004167kg/s
then the answer becomes,
0.0004167 x 20
= 0.0083 N
Priyadarshini said:
Oh!
Even then,
0.0004167 x 20
= 0.0083 N
I repeat, check your mass flow calculation again. How many seconds are in 1 minute?
Can I recommend you work out the number of kg/s using a pencil and paper rather than a calculator.
90 kg/min you should be able to work out in your head. o_O
Likes Adoniram
F=ma--?
Ft=mv-mu
90kg/min=0.025kg/s
This is m/t
F= 0.5N
The answer is 30N
What is Ft exactly?
Try applying basic principles:
F = ma is what we usually use when applying the 2nd Law, but a more appropriate form might be:
F = d/dt (m*v) = v*(d/dt m) + m*(d/dt v)
In the case of constant mass, this reduces to F = ma. In the case of constant velocity (this problem), this can be reduced to F = v*(d/dt m)
You are given the rate of water being pumped, which is in units of kg/min (can be converted to kg/s). This looks a lot like... dm/dt, right?
So, you can calculate the force being pressed back against the person holding the hose. But you are asked how much force it takes to keep the hose from moving. If that's what you want, what is true about the total acceleration of the hose? Now apply that to the 2nd Law, and what do you get?
Whoops! It's 1.5kg/s. It works now. Thank you!
Adoniram said:
What is Ft exactly?
Oh,thanks!
What is force?
Force is a physical quantity that describes the strength or intensity of a push or pull on an object. It is measured in units of Newtons (N).
How is force calculated?
Force is calculated by multiplying an object's mass (in kilograms) by its acceleration (in meters per second squared). The formula is F=ma, where F is force, m is mass, and a is acceleration.
What is the unit of force?
The unit of force is the Newton (N). Other commonly used units of force include pounds (lb) and kilograms (kg).
How much force is needed to move an object?
The amount of force needed to move an object depends on its mass and the surface it is being moved across. The greater the mass of the object, the more force is needed to move it. Additionally, rougher surfaces require more force to move an object compared to smoother surfaces.
What factors affect the force needed to be exerted on an object?
The force needed to be exerted on an object is affected by its mass, acceleration, and the presence of other forces (such as friction or gravity). The type of surface the object is being moved on and the direction of the force also play a role in determining the force needed.
17K
  • Mechanical Engineering
14K
