Force on 500g Particle: Velocity at t = 2s
  • Thread starter Thread starter bestchemist
    Force Particle
A 500g particle experiences a force Fx = (4−(t/s)²) N, which varies from 0 N at t = -2 s to 4 N at t = 0 s and back to 0 N at t = 2 s. The initial velocity at t = -2 s is vx = -4.0 m/s. Participants discuss the appropriate equations to use for calculating the particle's velocity at t = 2 s, noting that the force is not constant. The confusion arises over the application of formulas and the interpretation of velocity solutions, which include both positive and negative values. Ultimately, the correct approach involves calculating the average force rather than using an incorrect formula.
bestchemist
A 500g particle has velocity vx = -4.0m/s at t = - 2 s. Force Fx = (4−(t/s)2) N is exerted on the particle between t = - 2 s and t = 2 s. This force increases from 0 N at t = - 2 s to 4 N at t = 0 s and then back to 0 N at t = 2 s. What is the particle’s velocity at t = 2 s?
I'm not sure if the answer is 4 m/s. can someone check if I do it right?
V2 = V02 + at
v= v0+ (F/m)t
v = -4m/s + (0/0.5)*2
v= 4m/s
v= v0+ (F/m)t requires a constant force, or you have to calculate the average force. You cannot use the force at some arbitrary point in time here.
The first equation looks odd.
How did you get the last line from the line before?
It doesn't have constant force so which formula do I use?
v = 4 m/s?
I got that from plug in v02
v0 = -4 m/s
so I thought it would be 4 m/s since I have to take square root to get v
Is it wrong? lol
How are the velocity as function of time and the force related?
Alternatively, calculate the average force.
v0 = -4 m/s
The first formula was wrong anyway. You can see it if you check the units.
Is it wrong? lol
v2=16m2/s2 has two solutions: v=4m/s and v=-4m/s. But the formula you used was not right anyway.
I figure it out! Thank you :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
