Force on Stopper in UCM & Hanging Washer Relationship
The discussion revolves around the relationship between the weight of hanging washers and the force acting on a stopper in a system involving uniform circular motion (UCM). Participants are examining the forces at play, particularly the tension in the string and gravitational forces, while considering the implications of equilibrium and centripetal force.
  • Mixed
  • Participants explore the forces acting on both the stopper and the washers, questioning how these forces relate to one another. There is an attempt to clarify the concept of equilibrium in the context of the system's dynamics.
Some participants have provided insights regarding the tension in the string and its role in providing centripetal force for the stopper. Others are still grappling with the relationship between the forces and the concept of equilibrium, indicating ongoing exploration of the topic.
There is mention of a diagram that is referenced but not visible to all participants. The assumption that L equals R is noted, along with a discussion about the geometry of the situation and the implications of the angle of the string.
Klymene15
What is the relationship between the weight of the hanging washers and the force acting on the stopper by the string?
Here is the diagram provided by the book: http://www.goodreads.com/photo/user/5034346-kylaia-formerly-known-as-klymene?photo=454140
It also says to simply assume L=R
ƩF=ma, where the sum of the forces equals mass times acceleration.
ƩF=(mv2)/r, where the sum of the forces on an object in rotation equals mass times velocity squared, all divided by the radius
W=mg, where the force of the weight equals mass times the acceleration due to gravity (9.8)
The only force acting on the stopper, since it is in rotation, is the tension of the string.
ƩFstopper=(mstoppervstopper)/r
There is tension and weight acting on the washers.
ƩFwashers=Twashers-Wwashers=0
Therefore, Twashers=Wwashers=mwashers*9.8
I'm guessing that somehow, the system has to be in equilibrium, because that's the only way anything could be put in a relationship. But I don't see how it could possibly be in equilibrium. And I don't understand how to relate the forces on the washers to the force acting on the stopper.
It's all purely theoretical, so there are no given numbers.
It is far from theoretical! I can't see the picture you ahve attached but this reads like a standard PSSC [Physical Science Study Committee] Practical exercise.
PSSC was a Senior High Text and Prac manual developed/written in the 1960s and used in schools for many years from then.
Well, the system is not in equilibrium in the sense that there needs to be a net centripetal force acting on the rotating object in order to enable circular motion.
However, the sum of the forces on the washers will be zero. The tension in the string and the gravitational force acting on the washers means that the washers are in equilibrium - which makes sense since they aren't accelerating.
What provides the centripetal force on the rotating stopper?
The tension in the string.
What provides the tension in string?
The force of gravity acting on the washers.
cheers
cheers
All good.
ANd the reference to "let L = R" is allowing for the fact that the string from tube [I assume the string goes through a tube - still have not seen the picture] to the stopper is not exactly horizontal.
The tension must be providing an upward component to balance the (small) weight of the stopper.
Geometry of the situation will show that the actual radius of the circular motion is L.cosθ, but then the actual horizontal component of the tension is T.cosθ so the "droop factor" is rendered irrelevant. [θ was the angle below the horizontal that the string is angled down due to the weight of the stopper]
  • · Replies 17 ·
9K
  • · Replies 24 ·
9K
