Calculating Velocity of a Cannonball After Varying Force
  • Thread starter Thread starter Cherrybawls
    Force Velocity
The discussion revolves around calculating the velocity of a cannonball shot from a cannon with a varying force of 2000-100,000t. The problem assumes no external forces like gravity and focuses on the acceleration of the cannonball. To find the final velocity, participants suggest integrating the acceleration function or calculating the area under the acceleration versus time graph. The initial velocity is considered to be zero, simplifying the calculation of the final velocity. The conversation highlights the importance of understanding calculus concepts for solving such problems.
Cherrybawls
A .8kg cannon ball is shot out of a cannon with force 2000-100,000t. When the ball leaves the cannon, the force is zero. What is the velocity of the ball as it leaves the cannon.
Although the problem doesn't specify, I assume there is no gravity or any other external forces since there is no angle of the force or cannon given.
F=ma
Unfortunately, I have not learned how to solve equations dealing with varying acceleration, so I don't really know what to do...
I found that the cannon ball leaves the cannon at t=.02, but I don't know what to do once I have that to find the final velocity...
Hi Cherrybawls, welcome to PF!
The easiest way to do it is to integrate the a(t) function (acceleration as a function of time) in order to get the final velocity:
v(0.02) - v(0) = \int_0^{0.02} a(t)\, dt​
If you haven't done any calculus, then the above will probably not mean much to you. However, another method, which is *entirely equivalent* is to compute the area underneath the a vs. t graph, over that time interval. That will give you the change in velocity over that time interval. In this case, I think we can assume that the initial velocity, v(0), is 0, so that the change in velocity is just equal to the final velocity achieved.
Well, I am learning calculus now, but we have not yet gotten to integrals so I will go ahead and try the second method you mentioned, thank you so much
