How Much Force Is Needed to Compress Air in a Sealed Tube?
  • Thread starter Thread starter Negativ3
    Air Force
To calculate the force needed to compress air in a sealed tube, the ideal gas law (PV=nRT) is essential. The initial volume of air is 1005 cubic feet, and the final volume after compression is 904 cubic feet. The pressure change from 1 atm must be considered, as compressing the air increases its pressure. The force can be determined by calculating the pressure difference and multiplying it by the cross-sectional area of the tube. Understanding these principles will aid in deriving the required force for the compression.
Negativ3
I have a tube 40' long by 8" internal diameter, sealed at one end.
Assuming an ideal plunger is inserted into the open end, how much force would be required to compress the air (starting at 1 atm) from 40' (1005 ft/cu) to 36' (904 ft/cu)?
Any hints as to the calculation required for this would be appreciated.
Thank you.
Thank you.
Are you familiar with the ideal gas law?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
