Fizic
- 21
The two blocks (with m=16kg and M=88kg) shown in Fig. 6-56 are not attached. The coefficient of static friction between the blocks is \mustat=0.38, but the surface beneath the larger block is frictionless. what is the minimum magnitude of the horizontal force \vec{F} required to keep the smaller block from slipping down the larger block?
Fig. 6-56 looks approximately like this.
...______ ________
\vec{F}.|..m...||...|
...|_____||...M...|
.....|_______|
_________________________________
FRICTIONLESS GROUND
\sum\vec{F}=m\vec{a}
\vec{F}fric=\mustat\vec{N}
I denote \vec{F} from the problem text as \vec{F}A
I denote the force of block m and block M, \vec{F}mM
Likewise, the force of block M and block m is denoted \vec{F}Mm. I treat this as the "normal" force for the friction equation, but I'm not sure if this is correct.
Fgravm=mg=156.8 N
\vec{a}=\vec{F}A/104
\vec{F}mM=\vec{F}Mm=\frac{88}{104}\vec{F}A
\vec{F}fric=\mu\vec{F}Mm=.38*\frac{88}{104}\vec{F}A=.322\vec{F}A
To prevent downward motion \vec{F}fric must cancel out (i.e. be at least) \vec{F}gravm
\vec{F}fric=\vec{F}gravm
.322\vec{F}A=156.8N
\vec{F}A=487.7 N
Final answer 487.7 N
Thanks
