Building Force Sensors to Understanding and Creating Your Own
The discussion focuses on building force sensors for a project related to measuring the force of water during swimming. Key suggestions include using load cells or strain gauges to measure force effectively. The project is time-dependent, emphasizing the need for a sensor that can be rebuilt if necessary. The individual is uncertain about the magnitude of the force they want to measure, which is crucial for selecting the appropriate sensor design. Understanding these factors is essential for successfully creating a custom force sensor.
big_zipp
I have to do a project involving force sensors. I was wondering if anyone knew if there is any good books on how to build them or a book that explains how they work so I can build my own.
You probabably don't want to consider building your own sensor, unless you want to measure something rather exotic and building the sensor is a significant part of the project.
You don't say anything about the magnitude of force you want to measure, or if it is time dependent (and if so, what is the frequency range you are interested in).
Two standard methods are to use a load cell, or use strain gauges to measure the strain in a part of the structure that transmits the force (e.g. in a rod pushing on something).
The project is time dependent and it involves the force of water during swimming. So my idea is that I want to find a way to build my own sensor so if I would have to rebuild the multiple sensor I can.
For the magnitude of the force is what I want to test. I have no idea how much force is being used.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
