Forced oscillations of a linear system
The discussion revolves around a lab experiment analyzing the forced oscillations of a chain of metal bars connected by nylon wire, simulating wave transmission. The experiment revealed unexpected frequency peaks in the Fourier spectrum, including significant oscillations at three times the driving frequency. Participants considered the effects of rotational inertia and the potential for mode conversion, suggesting that the bars might oscillate in multiple directions rather than solely vertically. The conversation highlights the complexity of the system's behavior, particularly the influence of imperfections and the dynamics of the nylon wires. Understanding these factors is crucial for accurately interpreting the observed oscillation patterns.
watty
Hello,
I am currently working on a lab in which we are studying the behaviour of chain of metal bars attached together with nylon wire in such a way as to to mimic the ability of solids or liquids to transmit a wave.
After studying the normal modes of the system as well as the quality factor, we excited the system at frequencies not equal to normal modes and analysed the frequencies present using an optical detector wired through a computer that can perform a Fourier analysis of the spectrum.
When the system was being driven, we expected to see only one frequency present in the Fourier spectrum: that of the driving oscillator. However we also saw two very small peaks at normal frequencies as well as a significant peak at what appeared to be 3 times the driving frequency.
The two small peaks I can understand as maybe imperfections of the system, ie the forced oscillation does not fully overcome the natural properties of the system but I don't understand why the system is also oscillating at 3 times the driving frequency.
NB. there is also a normal mode reasonable close to this significant unexplained peak.
When you theoretically analyze the propagation of waves in this chain, are you fully accounting for the rotational moment of inertia in the individual metal bars? The metal bars have both center-of-mass motion (linear inertia) and rotational inertia. Could this cause mode-conversion?
Bob S
no i have not taken this into account. you mean that they are oscillating not just on one axis but in several directions? this could be the case. each metal bar is attached at each end to two long nylon wires. the wires are at high tension but there could be some extension and contraction in the wires and i suppose the bars are not moving exclusively up and down but also left and right too. Is this what you mean?
ps. mode conversion? what does this mean?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
