Forced Question Homework: Water Skier Towed Behind Speedboat & Ball in Toy Wagon
  • Thread starter Thread starter quah13579
quah13579
A barefoot water skier is towed behind a speedboat at constant velocity.
(i)
(a) Draw a side on diagram of the water skier and on your diagram label the directions and names of the forces acting on the water skier.
(b) What are two relationships between the magnitude of these forces?
(ii)
(a) When a ball is tossed straight up, it momentarily comes to rest at the top of its path. Is it in equilibrium during this brief moment? Give a reason for your answer.
(b) Consider a ball at rest in the middle of a toy wagon. When the wagon is pulled forward, the ball rolls backwards. Briefly account for this using Newton's first law.
I am not sure how to do(i) .
(ii)(a) I think the answer is yes, but I am sure the reason.
(ii)(b) I understand the question, but I don't know how to use theory to explain this.
For (i) you will have three basic forces acting on the skier: gravity, the pull from the rope they are holding and the force of the water on there feet. (b) is getting at the fact that the skier is at a constant velocity therefore the forces must be in equilibrium according to Newton's first law. Once you draw the force diagram it will be more apparent how this works.
In (i) (a) I believe the question is referring to equilibrium of forces. drawing a force diagram of the ball while it is in the air might help to answer this question.
In (i) (b) the question is worded a little funny. Another way to say the second sentence might be to say "When the wagon is pulled forward, the ball remains stationary (which is backwards relative to the wagon)". Again draw a force diagram and think about the forces acting on the wagon and the forces act on the ball, which is touching but not physically connected to the wagon.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
