Forces and work on an incline help
The discussion revolves around a lab experiment measuring the force on a concrete block (15.8 kg) on an inclined wooden ramp. As the ramp angle increases, the force required to pull the block also increases, which aligns with expectations. The coefficient of friction is being analyzed at various angles, revealing values greater than 1 at around 47 degrees, which raises questions about the calculations. Participants are considering the normal force as a cosine function of weight and the parallel force as the applied force up the ramp, but there is uncertainty about the accuracy of this approach. Clarification is sought on how to incorporate the components of weight down the incline into the equation for calculating the coefficient of friction.
northern expo
we are conducting a lab where measurement of force on an incline is necessary. the mass which is pulled is a small concrete block (15.8 kg) on a wooden ramp. as the ramp is increased the force changes (increasing) which is expected. last we need to look at the coefficient of friction at different angles of measure. if we are pulling the block up the ramp at a constant we are finding a force of oppositon due to friction and the force normal. ok, as we are calculating we are finding that the value of this coefficient is increasing and at about 47 degrees of the horizontal plane this value is greater than 1! at the lower angles it is a reasonable value. what are we forgetting? yes we are considering that the force normal is a cosine function of the weight and the force parrallel is the froce we are applying up the ramp. doesn't seem to be correct. what are we missing?
F = m*g*sinθ + μ*m*g*cosθ
I'm just saying, since you didn't mention the component of weight down the incline at sinθ.
is this F value you are indicating the net F ? We have a measured value for the force up the incline, how is this value
included into my equation to find the coefficient value?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
