Forces on adjacent accelerating bodies
The problem involves calculating the acceleration of two bodies, A and B, when they are attached and subjected to the same force. Body A has an acceleration of 0.640 m/s², leading to a calculated mass of 1.5625 kg. The next step is to determine the mass of Body B using its acceleration of 0.359 m/s². Once both masses are known, the combined mass can be used to find the acceleration when the same force is applied to both bodies together. The discussion emphasizes the importance of correctly calculating the masses to solve the problem accurately.
subzero800
The same force that gives the standard 1 kg mass an acceleration of 1.00 m/s2 acts first on body A, producing an acceleration of 0.640 m/s2, and then on body B, producing an acceleration of 0.359 m/s2. Find the acceleration produced when A and B are attached and the same force is applied.
ƩF=ma
I started by trying to figure out the mass of body a by doing 1 N/.640 m/s2 and I have 1.5625 Kg for Body A--I'm not sure if this is correct nor how to complete the problem.
So far, so good. You found the mass of body A. Now find the mass of Body B.
