Understanding Form Factor: A Physical Meaning
In summary, the form factor in electron nuclear scattering is a ratio of observed cross sections that takes into account the target's finite size. It can be interpreted as a Fourier transform of charge or current density and is used to study the internal structure of particles. Hadronic form factors and coupling constants are not equivalent concepts, but decay constants can be related to form factors in certain cases. High energy experiments can measure decay constants for pseudoscalar mesons.
jaleyil
ıs anyone know about what the physical meaning of form factor is?
The experimental scattering form factor F(q2)2 in electron nuclear scattering is the ratio of the observed differential elastic scattering cross section (dσ/dΩ cm2 per steradian), corrected for finite mass, to the Mott differential scattering cross section (similar to the Rutherford cross section). See Equation (1) in
http://www.google.com/url?sa=t&sour...x9W5Ag&usg=AFQjCNGiqQANS9CGyQNEuBgQWcxpztMTOQ
The form factor F(q2)2 (a function of the momentum transfer q), represents the reduction of the observed cross section due to the finite size of the target proton or nucleus, relative to a point-charge target. For a point-charge target, F(q2) = 1 for all q.
Bob S
The form factor is something liek the Fourier transformation of the charge or current density. Attention: this interpretation becomes dangerous in the relativistic domain.
Precisely.
See Equations (2) through (4) in
The Appendix gives some interesting useful form factor transformations to/from momentum space from/to physical size. Note that nowhere are any radiative corrections mentioned. The discovery of quarks was based on the extension of form factor analysis of electron-proton scattering at ~ 20 GeV.
Bob S
In electron-proton scattering (deep) inelastic scattering becomes important; the structure functions F(Q²,x) are generalizations of form factors.
can we say hadronic form factor and coupling constant are equivalent concepts or is there any difference between them?
There is a difference.
The coupling constant describes how charge and current densities interact. The form factor "is" the (Fourier transform) of the density.
Why do you think they are the same?
Depending on the context, Hadronic Form Factors and DECAY constants are equivalent concepts, where a decay constant for some pseudoscalar meson M:
[tex]
\langle 0| q_1 \gamma^\mu (1-\gamma_5) q_2 | M > = -i f_M p^{\mu}_{M}
[/tex]
is part of the parametrization of the matrix, in this case a constant, but say for a vector meson decay
[tex]
\langle \gamma | q_1 \gamma^\mu (1-\gamma_5) q_2 | V > = F_V (q^2) \epsilon^{\mu \nu \alpha \beta} \eta^\nu p_{V\alpha} p_{\gamma \beta} + i F_A (q^2) [\eta^\mu (p_V \cdot p_\gamma ) - p^{\gamma \mu} (p_V \cdot \eta)]
[/tex]
Where Fv and Fa are the form factors of the parametrization of this decay. Similar ideas but the "scalars" in the second case are functions of the momentum transfer, while in the first must not depend on momentum, as there is no transfer.
Maybe that's what you meant?
Thanks a lot Tom. I have another question. Can we measure decay constant directly from high energy experiments ?
Which decay constant are you talking about?
hadronic decay constant
What is form factor?
Form factor refers to the physical size and shape of an object or device, as well as its overall design and layout.
Why is form factor important?
Form factor is important because it can affect the performance, functionality, and usability of a device. It also plays a role in the design and aesthetics of a product.
How is form factor measured?
Form factor can be measured in various ways, depending on the type of device. For electronics, it is often measured in dimensions such as length, width, and height. For other objects, form factor may be measured by volume or weight.
What are some common form factors?
There are many different form factors, but some common ones include ATX, Micro-ATX, and Mini-ITX for computer motherboards, and standard, micro, and nano for SIM cards.
How does form factor impact compatibility?
The form factor of a device can impact its compatibility with other components or devices. For example, a motherboard with a specific form factor may only be compatible with certain types of processors or cases. Similarly, a SIM card with a different form factor may not fit into a device designed for a different form factor.
  • Science and Math Textbooks
