Formulas For Engine Cylinder Perssure
60 replies · 14K views · last reply
Jason Louison
Hi! I am a new member to this great Forum! I am so excited to be a part of this wonderful community. Anyway, as the title suggests, I am looking for a way to calculate the pressure in each cylinder of any Four Stroke Engine at any given crank angle of Cylinder One. I have been trying creating a spreadsheet based on a very interesting PDF document I found a couple of weeks ago. One cylinder is fine, but trying to make the formulas for cylinder pressure for each cylinder flexible to change/adapt to the change in degrees per cylinder is getting to be really frustrating. Does anyone know a whole, single function out there for cylinder pressure?
Thanks ~ Jason Louison.
Based on the crank angle alone, no, there is not an equation for pressure. There are many more variables involved beginning with if there is a piston offset or not.
Thanks, Removed Unnecessary Data Tables, But I think The Turning Moment Diagram is off.
Assume the forcing profile is the same then just phase each cylinder according to firing order.
I'm on my phone, so can't see the zip properly.
My first thoughts also but I don't think that's what he is asking. I think the question is; When cylinder 1 is calculated for pressure at a given crank angle is there an equation that will concurrently give the pressure at the remaining cylinders at that same moment. It's why I brought up offset pistons because then the stroke timing is an additional variable to factor in. Typically offset results in a longer power stroke in terms of time but the velocity of the piston is not linear so it's different at every cylinder at any given single moment. Equations for time are not the same as those for angle. The equation would need to include conversions of variables. From there cylinder head valve timing and air flow and air pressures have to be factored in at every crank angle in relation to the number 1 cylinder in the OP's example. How precise is the equation going to be depends on how far the inclusion of variables is going to go. If there is a single equation for this that covers all engines it's one I've never seen or heard of. I'm not even sure if this is possible to determine from mapping performance through the typical ECU. Not that it wasn't possible. It was a matter of decisions about what needed to be recorded for the family car. Tuner chips even recorded at predetermined crank angles for specific engines and not continuously for the entire 720 degrees of a complete cycle.
How the hell do you view the data? What is the fundamental approach to modelling this? As I can't really make sense of what you've just said. I can't tell if I'm just not getting context.
Fundamentally in every multi cylinder engine; what one piston does (whatever that may be) they all do. If he has a working model for one cylinder, as stated , it's just a case of applying the same thing at a different time.
Solved (sort of)! I just had to add some conditional statements that change the value depending on the crank angle for ALL cylinders.
"0°-180°" Argument:
IF(AND($A2<180),0.9×Atmospheric Pressure(psi)
"180°-360°" Argument:
IF(AND(Crank Angle≥180,Crank Angle<360),(Atmospheric Pressure(psi)×((Cylinder Clearance Volume+Cylinder Displacement Volume)÷Total Immediate Cylinder Volume)^Expansion Coefficient)
"360°-540°" Argument:
IF(AND(Crank Angle≥360,Crank Angle<540),(Maximum Pressure(atmospheres)×(Cylinder Clearance Volume÷Total Immediate Cylinder Volume)^Expansion Coefficient),
"540°-720°" Argument:
IF(AND(CrankAngle≥540,Crank Angle<720),1.1×Atmospheric Pressure (psi)
And then a 720°-900°argument, a 900°-1080°, and so on. Combined, these formulas ensures that cylinder pressure is accuratley calculated for all cylinders, no matter what angle they start at or end with!
I would share the spreadsheet, but the file is too large to upload here, unfortunately.
I will upload pictures of the revamped spreadsheet though. Thanks!
Line graph titled Piston Velocity vs. Crank Angle, plotting velocity in mm/degree against crankshaft angle from 0 to 720 degrees, showing six sinusoidal curves labelled Cylinder One to Cylinder Six, alternating red and blue, with peaks near 260 and troughs near -260.
Line graph of turning moment in N/m against crankshaft angle from 0° to 720°, showing six coloured curves for cylinders one to six, each with a sharp positive peak of about 870 N/m followed by a smaller negative trough.
Line graph titled Piston Position vs. Crank Angle, height in mm against crank angle 0 to 720 degrees, with six sinusoidal curves for Cylinders One to Six alternating between about 95 and 190 mm.
Some of the graphs I have made so far!
I understand but as I said he's asked for an equation to do it all at once. He's also asked for a an existing equation which the equation would need to be universal for every engine. You can't assume the valve timing which effects pressure for every engine is the same. Can't assume combustion time measured in degrees of crank angle is the same for every engine. How many variables in the end are there going to be for a universal equation? If you are aware of an function that does this please let me know.
Getting the pressure at 8 different crank angles and then adding them up is not one equation. Or as the OP put it, one function.
Edit, Jason's last 2 posts weren't here when I started but I stand by what I wrote. Programming a series of arguments for graphing is not the same as a single function for any engine in spreadsheet form.
I think you misinterpreted what he wanted to do. It's pretty clear that he had a single cylinder model he was happy with and just wanted to phase the calculation. This is what he has done by the conditional statements. By universal engine he meant 1,2,4,6,8,12 cylinder etc.
OP your model is effectively turning the PV diagram of the cycle into a torque vs crank angle. Are you going to consider inertia effects and friction?
EDIT: Or have you, I can't tell if inertia is already in there from the graphs. : /
Yes, there are Inertia Contribution columns in the data tables for each cylinder. The Pressure-Volume diagrams have not been implemented yet, but will be soon :)
Is this a run moving 'quasi-statically' then? As that torque profile looks like it's only based on cylinder pressure.
What do you mean by that?
That is for a four cylinder model. Sum up those four cylinder torque values to get torque @ the crank, and looks at the profile.
Try doing this with the model running with different engine speeds.
Line graph titled Pressure vs. Volume, plotting pressure in N/mm against volume in liters, showing a closed cycle with a steep pressure spike at minimum volume and expansion curves falling toward the right.
:D I'm so stoked! This is going so well right now!
The question now is how do I distort that p-V diagram given peak torque rpm's and current rpm's...
It makes sense to keep it in this thread, as it's a natural progression. Distorting the p-V diagram is where things get 'wooly', and this is where Work Hard Play Hard's comment about not having a single formula is oh so true. There isn't really any way to calculate it by hand.
However, there are some broad assumptions we can make that moves the model closer to reality. For each stage of the process we can introduce assumptions that cause losses. You may want to start by reading the finalpaper.pdf again with the assumptions they make.
eg. Ideal otto assumes isochoric combustion (ie instant prssure raise). - We know this isn't true in reality, the burn begins bTDC and peaks aTDC.
Obviously you're right but I'm not sure it's necessarily so clear.
1. I am looking for a way to calculate the pressure in each cylinder of any Four Stroke Engine at any given crank angle of Cylinder One.
2. I have been trying creating a spreadsheet
3. One cylinder is fine, but trying to make the formulas for cylinder pressure for each cylinder flexible to change/adapt to the change in degrees per cylinder is getting to be really frustrating.
4. Does anyone know a whole, single function out there for cylinder pressure?
As I said in my first comment, my first thoughts were the same as yours but #3 suggests otherwise with the other statements.
Have you seen this Jason? It gets referenced and cited often.
http://r.search.yahoo.com/_ylt=AwrBTzvmncRYBIUAczxXNyoA;_ylu=X3oDMTByNXM5bzY5BGNvbG8DYmYxBHBvcwMzBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1489309286/RO=10/RU=https%3a%2f%2fwww.hcs.harvard.edu%2f~jus%2f0303%2fkuo.pdf/RK=0/RS=UrH3DzAaKtGEVFDzfmDAgHUV9CA-
No, I haven't, but it seems like a good resource. Right now I am trying to think of ways to incorporate "losses" in my spreadsheet, so I can get a realistic p-V relationship like this:
Plot of pressure in N/m/m (scaled by 10^6, axis 0 to 12) against an unlabeled horizontal axis from 0.5 to 5, with blue and red curves that fall steeply and flatten toward zero.
Here is just a little dummy engine I made: A turbocharged 2.5 Liter Inline Five-Cylinder Engine.
Spreadsheet table of engine parameters with red input values, including 5 cylinders, 3739 RPM, 86 mm bore and stroke, 135 mm connecting rod length, compression ratio 8.68562, and torque at crankshaft 312.7570 lb/ft.
Line graph titled Piston Position vs. Crank Angle showing height in mm from 0 to 180 against crankshaft angle from 0 to 720, with six sinusoidal curves labelled Cylinder One to Cylinder Six, each offset in phase.
Line graph titled Piston Velocity vs. Crank Angle showing six sinusoidal curves for Cylinder One to Cylinder Six, velocity in mm/degree on the vertical axis from -1000000 to 1000000 against crankshaft angle from 0 to 720 degrees.
Pressure vs. Volume plot in N/m/m against Liters, showing a closed loop with a steep rise at about 0.07 L and a long curved decline to about 0.56 L, with axis values 0 to 16000000 and 0.075 to 0.600.
Line graph titled Turning Moment vs. Crank Angle plotting torque in N/m against crankshaft angle from 0 to 720 degrees for six cylinders plus the total torque at the crankshaft, shown as a black curve with six periodic peaks near 1000 N/m.
If you guys think anything os off so far let me know! :)
I was wondering if your simulation was for an actual engine or as you say, "a dummy engine?" It might be helpful if you could move on from the dummy engine to an actual engine you can compare your simulation model to. Both the simulation model you referenced here and the one I just added use actual engines to compare their models to. The paper I added deals with contrasts between the model and engine in more depth then your reference and I believe it is a bit more specific and maybe even precise.
Being you're a student I think suggestions at this point are appropriate for identifying, defining and correcting for losses in your model. Again get an actual engine to apply you model to. If you don't your model and coinciding paper will come down to, "I did this because. . . .I think based on. . . ," which probably won't carry as much authority as working with actual deviations between your model and an engine will. If you don't have access to actual data ask for permission to use someone else's. I don't think you'll have much difficulty getting it.
For methodology I would pursue comparison and contrasting. Overlay the actual engine graphs with the simulation and where they match, define why. Where they don't match pursue reasons why they contrast. Document the process for your paper even when you get it wrong because "the wrong," should show up somewhere in your simulation and hopefully you can, or with help from here you can present the effects of your pursuit and explain the error. In the papers you have there are their, "we were wrongs."
I'm not speaking for anyone else and their thoughts or input but I can suggest a couple of places to start.
The compression ratio stated for an engine is usually the "Static" ratio. It's what you use in your model arguments. The compression stroke is presented as BDC to TDC. The intake valve doesn't close until after BDC though. This is the "Dynamic" ratio which is always lower then "Static" ratios. There is no formula for converting cylinder pressure to compression ratio or vice versa. What effect does that have on cylinder pressure in your model?
Maybe Chris can help you with this since I believe this graph is his. What is going on in every other trough in the V8? Why the little skip with this pattern? Jason, how does this torque curve compare to yours?
Chris, have you ever seen a simulation that actually factored in or out, the flywheel? Or further yet, factoring for engine balances? I'm thinking of:
https://en.wikipedia.org/wiki/Engine_balance
Line graph of torque (Nm) against crank angle (deg) from 0 to 800 for three engines: single cylinder, V8 and straight 4, showing periodic torque pulses.
Line graph of torque in Nm against crank angle in degrees from 0 to 720 for three engine types: single cylinder, V8 and straight 4, showing repeating torque pulses.
Not quite :( If I set the Cylinder Pressure not to be darn huge maybe I could get some great results like this one. This is a single cylinder engine in my diagram.
Line graph titled Turning Moment vs. Crank Angle, plotting torque in N/m against crankshaft angle from 0° to 720°. The curve starts at zero, rises to about 30 N/m near 90°, crosses zero at 180°, dips to about -210 N/m near 330°, spikes to about 545 N/m just after 360°, then falls back and goes slightly negative near 630°.
So I just need to tweak some parameters and I should be good. As for the "dummy" engine, your absolutely right, so I will now do an engine very close to me: The TOYOTA 2JZ-GTE. (Its even in my profile pic!)
Jason Louison said:
Table of engine parameters with red input values and black computed outputs: 5 cylinders, 3739 RPM, bore 86, stroke 86 mm, con rod length 135 mm, compression ratio 8.68562, max pressure 2100, torque at crankshaft 312.7570 lb/ft, and others.
Are you somewhat infinitely confused about your units and values ?
Nidum said:
Are you somewhat infinitely confused about your units and values?
Yes. if you could read these and tell me why or how they turning moment diagrams are different, and why they are 0 at 90°, that would be a great help.
OP your turning moment is based on cylinder pressure only. The extra 'hump' are caused by the reciprocating inertia of the piston & conrod.
Imagine you hooked the crank up to an electric motor. No firing. You'd get torsional forcing on the crank due to the accelerations of the piston mass.
An engine you have an affinity for is a good choice. For the graph comparison I was referring more to how "clean" yours is to Chris's actual engine.
Chicken or the egg? Would working on units and values help him more to get to where he wants to go or would helping him get to where he wants to go help with understanding units and values? It's a serious question. Would the visual of units and values at work in a simulation help with understanding the relationships of units and values as the simulation is tuned more to an actual engine or should the relationship between units and values be fully grasped first? What's more efficient? Chris? You sure understood what was being asked before I did.
Wow. Turns Out the Formulas I have been using this whole time were wrong. Following this, the spreadsheet has had a series of successful updates! :)
More realistic, but not quite right yet. Do that same engine at a few different speeds.
Before you actually do it cosider the following:
What should happen to mean piston speeds?
What would this do to piston acceleration, hence forcing?
What would you expect to see to the torque cyclic graph?
