Formulating an Eigenvector Equation
  • Thread starter Thread starter 2.718281828459
    Eigenvector
The discussion centers on deriving the eigenvalue equation for a double pendulum project, specifically addressing the equation (K - Mω²)α = 0. The user is confused about manipulating the equation to find eigenvalues, as their approach of multiplying by M's inverse did not yield correct results. Participants suggest checking the matrices K and M for errors and recommend finding the determinant of (K - ω²M) to identify the correct eigenvalues. The determinant method is emphasized as a reliable approach to solve for the normal mode frequencies in the system. Understanding this method is crucial for accurately determining the system's behavior.
2.718281828459
Hello. I am working on a project with a double pendulum and I am currently looking for the normal mode frequencies. I don't think that's too important to answer my question, but in the derivation I hit a point that look like this:(K-M\omega^{2})\alpha=0. Here, K and M are 2x2 square matrices. I want to solve for the eigenvalue here, but this doesn't follow the form that I normally have with eigenvector equations. If I rearrange this, I get K\alpha=M\omega^{2}\alpha which has a matrix on each side. Naturally I thought to multiply by the inverse of M on both sides to get M^{-1}K\alpha=\omega^{2}\alpha. However, this didn't give the correct result. Why not? How should it be done?
You must have K or M wrong, or both.
Check again, or submit the original problem and your approach here.
Finding the eigenvalues of ##M^{-1}K## works. You must have made a mistake somewhere.
But you don't need to do that. Just find the determinant of ##K-\omega^2M##, and find the values of ##\omega## that make it zero.
$$\left|\begin{matrix} k_{11}-\omega^2m_{11} & k_{12}-\omega^2m_{12} \\
k_{21}-\omega^2m_{21} & k_{22}-\omega^2m_{22} \end{matrix} \right| = (k_{11}-\omega^2m_{11})(k_{22}-\omega^2m_{22}) - (k_{12}-\omega^2m_{12})(k_{21}-\omega^2m_{21}) $$
