Fortran, passing an array to multiple subroutines
The discussion revolves around passing an array to subroutines in Fortran, specifically addressing the issue of unintended modification of the original array when performing operations within a subroutine. Participants explore different methods to prevent the original array from being altered, focusing on Fortran 77 solutions.
  • One participant describes a scenario where an array is passed to a subroutine for logarithmic computation, but the original array is altered, leading to confusion about how to maintain its original values.
  • Another participant suggests using the %VAL function to pass the array by value, noting that this function is not standard in Fortran 77.
  • A different approach is proposed, where a new array is defined within the subroutine to store the logarithmic values, thereby leaving the original array intact.
  • One participant expresses uncertainty about the implications of the "real :: ar(n)" declaration in the original code, questioning its effect on the array's behavior.
  • A later reply confirms that defining a new array resolved the issue of overwriting the original array.
Participants generally agree on the need to prevent the original array from being modified, but multiple approaches are discussed without a consensus on the best method. Some methods are proposed as alternatives, but no single solution is universally accepted.
Limitations include the potential lack of access to certain functions like %VAL in standard Fortran 77, and the need for clarity on array handling and memory management in subroutines.
This discussion may be useful for programmers working with Fortran, particularly those dealing with array manipulation and subroutine design in Fortran 77.
Biederman
Hi guys,
I am kind of a newbie to fortran and I'd like to ask a simple question.
In the code below, I have a main program with one subroutine. It's a simple one.
In the main code I am filling an array with elements from 1 to 10. Then I am passing this array to a subroutine "sub", where I am computing the logarithms of the array elements. However, I don't want to return the array back into the main program. In fact, I want the the logarithms to be calculated in the subroutine only.
However, when I print the array elements just after the call to the subroutine, I notice that the array elements are actually the logarithms of the latter. When I print the elements before to the call of the subroutine, the elements print fine i.e 1,2,3,4...etc. How do say fortran not to alter the array elements in the main program. I am asking this because later, I need to pass the original array elements to a second subroutine. That is, if a call a second subroutine e.g "sub2" with the same arguments as the first one, I notice that the main program actually passes the logarithms i.e the elements which have been calculated in the first subroutine.
I hope my question is clear enough.
BTW: I prefer to use fortran 77. So, if you can help me by providing a fortran 77 solution, I'd appreciate that!
c***********************************************************************
implicit none
integer i,n
parameter(n=10)
real arr(n)
do i = 1, 10
arr(i) = real(i)
end do
print*,arr ! here it prints: 1,2,3,4 ...etc which is what I want
call sub(n,arr)
print*,arr ! here it prints the logarithm of the values, which is not what I want. I'd like the origininal array because I am going to pass it to another subroutine.
end
subroutine sub(n,ar)
integer i,n
real :: ar(n)
do i = 1, 10
ar(i) = alog10(ar(i))
end do
end
Technology news on Phys.org
You need to pass by value, not by reference. You could try this:
call sub(n,%VAL(arr))
The %VAL function is not standard in FORTRAN77, though. I take that to mean you might have access to it, or you might not. See this reference.
Hi Ackbeet,
Thank you for the link!
If I wanted to pass all the elements by values then I'd use : call sub(n, arr(1:10))
But either way, it prints the logarithms after the "call" statement rather than the original array.
Well, another option would be to define a new array in the subroutine, and not overwrite the existing array. So your subroutine looks like this:
Code:
integer i,n
real :: newar(n)
do i = 1, 10
newar(i) = alog10(ar(i))
end do
end
It's been awhile since I've done FORTRAN, so I'm not entirely sure what the "real :: ar(n)" line is doing in your original code. In any case, rest assured that if the argument 'ar' to the subroutine never appears on the LHS of an assignment operator, then it will remain in memory untouched.
Code:
integer i,n
real :: newar(n)
do i = 1, 10
end do
end
Thanks Ackbeet! Defining a new array solved the problem. You're right, in that way I am not overwriting the old array.
I appreciate your help!
Regards,
Abedin
You're very welcome!
  • · Replies 20 ·
  • · Replies 59 ·
12K
  • · Replies 29 ·
  • · Replies 25 ·
