Fortran Need Help with Writing Fortran95 Procedure
The discussion revolves around a user seeking assistance with a Fortran95 program that needs to read data from seven input files, perform calculations using a predefined procedure, and then write the results to an output file. The user is a beginner and is struggling with the correct approach to open multiple files, read data, and organize the output. Key points include the need to initialize arrays for data storage, use a loop to read from each file sequentially, and ensure that the output contains separate blocks of calculations for each input file. Participants suggest providing a sample of the input data for better guidance and emphasize the importance of reading the files and performing calculations before writing to the output.
anna2011
Fortran95 HELP!
Hi everyone,
I have problem with writing a procedure in Fortran. I'm a newbie so any help will be appreciated.
So the problem is as follow: I have written a program which reads some data from input file and then calculates some stuff using read values. Now what i have to do is to open more then just one file (seven actually) which have the same format as the previous one, the same extention but different names and the text string is not composed of the same number of letters, just the same extension. When i open all the files then i have to use the procedure i wrote and write all the data in one file.
Can anyone tell me how I can do that, I'm getting crazy becuase of that...
Thanks, in advance
Technology news on Phys.org
I think opening and writing is done as follows
Forgive me if I misunderstand your question
open(1,file='file1')
open(2,file='file2')
open(7,file='file7')
write(1) variable1
write(2) variable2
write(7) variable7
close(1,2,3,4,5,6,7)
Hi,
Thanks for quick reply.
So the idea is to read seven files, one by one, read from those files needed values and use the same procedure to calculate some values based on data read from each input file. And then in output file i should have seven separate blocks of calculations, for each input file.
Is this makes things more clear?
anna2011 said:
Hi,
Hi anna :smile: I am new to FORTRAN as well, but I think you need to do something like this:
1) Initialize some arrays to store the data in
2) Open all of the files
3) Use a "DO" loop to read all of the data into the arrays
4) Close all files
We can help you out, but it would be helpful if you could provide a short sample of one of the 7 files you wish to get data from. Just copy paste the first 5-6 rows of data from a file and wrap them in the "Code" tags located above by using the [URL]http://i12.photobucket.com/albums/a220/saladsamurai/codetags.jpg[/URL] button (this will preserve the formatting).
Code:
C1        2.1419561858E+00  2.1419561858E+00  4.2839123717E+00  0.0000000000E+00
O2        4.5849316264E+00  4.5849316264E+00  9.1698632528E+00  0.0000000000E+00
N3        4.0198698574E+00  4.0198698574E+00  8.0397397149E+00  0.0000000000E+00
H4        3.0070127032E-01  3.0070127032E-01  6.0140254064E-01  0.0000000000E+00
H5        3.1607842405E-01  3.1607842405E-01  6.3215684811E-01  0.0000000000E+00
N6        4.0198675021E+00  4.0198675021E+00  8.0397350042E+00  0.0000000000E+00
H7        3.0070127037E-01  3.0070127037E-01  6.0140254074E-01  0.0000000000E+00
H8        3.1606930741E-01  3.1606930741E-01  6.3213861481E-01  0.0000000000E+00
hope its enough.
Thanks a lot :)))
anna2011 said:
Code:
hope its enough.
Thanks a lot :)))
Hmm I'm afraid it's not enough. Could you explain what are those values for your program? These are the written values, the read ones?
Also they are weird (but might be right). For each molecule (or row I'd better say), the first column is equal to the second. And the 3rd column is worth 2 times the first. The last is always 0.
write(1) variable1
write(2) variable2
write(7) variable7
You forgot to read the files and do some calculations :)
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
