Four charges each Q in magnitude
  • Thread starter Thread starter britt
    Charges Magnitude
The discussion focuses on calculating the electric field at point B due to four charges arranged in a square. The total electric field at point B is determined to be E = (36/5)(q/L^2), with contributions from both positive and negative charges. It is concluded that both objects with different charges and masses would experience equal acceleration when placed at point B. The electric field is not zero at any point within the square, with specific equilibrium points identified, though their stability is debated. The participants emphasize the importance of understanding vector components in calculating the electric field contributions accurately.
britt
Four charges, each q in magnitude, are arranged in a square, two positive and two negative, in opposite corners. The square is L length on each side, and the charges are all in the same plane as shown in the diagram. Show work and units for full credit.
q+ -----B----- q-
| | L
q- ------------ q+
L
**vertical dotted line makes square but spacing corrects itself
A. Determine the magnitude and direction of the total electric field at point B (half way between the top two charges) due to all four charges as a function of q and L.
B. If placed at point B, which would accelerate faster, object 1 with a charge 2Q and mass M or object 2 with a charge Q and mass M/2? Why?
C. Draw the electric field lines in the plane of the square indicating the direction and general shape of the electric field generated by this charge arrangement. Hint: think about the electric field generated by two opposite charges.
D. Is the electric field zero at any point(s)? If so, where? Also, indicate any equilibrium point(s) and whether they are stable, unstable or neutral.
A. E=(36/5)(q/L^2)
B. Both are equal a = 2qE/m = qE/(m/2)
D. 0 at top of square going in towards B from + and towards B for -
What equation are you using for electric field strength?
Likes 1 person
E=k(q/R^2)
and adding
I got that from the bottom charges R=(sqrt(5)/2)L
and the other two cancel out because they go in towards B
E=k(q/(5/4)L^2)
the E-field contributions by the top charges are both rightward:
away from +Q , and toward -Q (toward being "negative away"),
but some of this is canceled by leftward E-field by the bottom charges.
What fraction of the E-field contribution by the bottom left -Q is matched by the +Q on bottom right?
Likes 1 person
The bottom left -Q and +Q would result in a leftward towards upper +Q but I thought the bottom ones would cancel out completely?
away from the positive and toward the negative; only their vertical components cancel ... their horizontals double.
Likes 1 person
so their force added would be 8kq/5L^2 .. ?
each E-field contribution is 4/5 kQ/L² , but that is along the diagonal. You need to find the horizontal component.
Likes 1 person
horizontal component: 2(4/5)(kQ/L^2)cos(180)+2(4/5)(kQ/L^2)cos(0)
Look at the triangle that you used to find the diagonal distance. The E-field contribution is along that diagonal.
The negative's contribution is mostly down, but a little bit leftward ... left is L/2 compared to the diagonal L√5 /2 ... that is, the diagonal contribution is √5 times as long as the horizontal part that survives.
So would the x component be:
Lcos(180)+Lcos(0)?
Ok (duh) it's running from b to the top charge(l/2)
Thanks for your help I never understand the x and y components
/_|
the Ex/E ratio is the same as the Lx/R ratio ... each = sin theta (the skinny angle)
so Ex = E Lx/R , leftward (negative)
The E-field contributions from the TOP charges are at 0° (both are rightward)
| \ E from bottom right +Q , upward
|__\
Ex
sin theta = Ex/E , but also sin theta = ½L /R ... so Ex = ½L /R * E
Okay so add ((L/2)/R)xE and EL/R then multiply by cos(180) + (8kq/5L^2) ?
Or is the component 1/2L/R *E ?
yes, pointing leftward, if you put the correct expression in for E. and R.
then you add these (subtract, actually) to the top Q's E-fields ; don't forget those, because they're much bigger!
Yes to the first post
Correction at end:: + (8kq/5L^2)cos(0)
Or two the Ex=(1/2)L/R * E ?
where did the 8 in the 8/5 come from?
don't confuse yourself by writing "cos(180)" when you mean leftward.
the triangle base is ½ ; the diagonal is 1.118 , so the base is .5/1.118 times as big.
the same ratio applies to the red arrows (E-field contributions)
http://www.science.marshall.edu/foltzc/addEsq.gif
