Simon Bridge said:
It helps us to help you if you attempt the problems as well. I'll type them out so you can see how to do it and so as not to inflict a word file on more people than we have to...
Thanks, Simon
1. Solve the following DE:
$$ \frac{d^2y}{dx^2}+3\frac{dy}{dx}+2y=2x+e^{-x} $$
seifkhalil, what do
you know about this problem? I presume that you are taking a "Differential Equations" course. Do you recognise this as being a "linear equation with constant coefficients"? Do you understand that the first thing you need to do is find independent solutions to the "associated homogeneous equation" which is
$$ \frac{d^2y}{dx^2}+3\frac{dy}{dx}+2y= 0 $$
Do you know how to find the characteristic equation, r^2+ 3r+ 2= 0?
Can you solve that equation? Since one root of the characteristic equation is -1, e^{-x} is a solution to the associated homogenous equation. That means you need to look for a "special" solution to the entire equation of the form "Ax+ B+ Cxe^{-x}".
2. Given that ##y_1 = e^x## is a solution of the following homogeneous differential equation :
$$y^{\prime\prime}-3y^\prime+2y=0$$ ...use the method of reduction of order to find a second solution y2 . Hence, find the general solution of the nonhomogeneous differential equation :
$$y^{\prime\prime}-3y^\prime+2y=5e^{3x}$$
Okay, do you know what the "method of reduction or order"
is? Since you are told that e^x is as solution, look for another of the form y(x)= u(x)e^x. Put that into the given equation and it will reduce to a first order equation for u(x).
3. 3- i) Find the Laplace transform of the following functions:
a) ##f(t)= \big ( 1-e^{t/2} \big )^2##
b) ##f(t)=\big ( \sin t + \cos t \big )^2##
Do you know what the "Laplace transform"
is? The Laplace transform of function f(x) is given by
L(f)= \int_0^\infty e^{-st}f(t)dt
ii) Find the inverse Laplace transform of the following functions:
a) $$\frac{1}{s^2(s-2)}$$ b) $$\frac{9s+14}{(s-2)(s^2+4)}$$
There is no simple way, such as integration, to find an inverse Laplace transform. You look up the basic ones in a table of transforms. You can typically use "partial fractions" to reduce fractions such as these to the "basic" ones.
4. Use Lapalace transform to solve the following IVP:
$$y^{\prime\prime}-6y^\prime+9y=t\; ,\; y(0)=0\; ,\; y^\prime(0)=1$$
Take the Laplace transform of both sides, which will include "L(y)", the Laplace transform of the uknown function. Algebraically solve the equation for L(y) then use a table of inverse transforms to find y.
