How does a converging lens create the Fourier transform of an aperture?
A converging lens creates the Fourier transform of an aperture by focusing spherical waves emitted from each point of the aperture to the focal plane, where the interference pattern is observed. While plane wave decomposition provides clarity, the spherical wave perspective is more physically accurate in understanding the lens's function. The lens effectively translates the diffraction pattern from infinity to the focal plane, allowing for the visualization of this pattern through a small aperture. Observing distant point sources through a small hole demonstrates this phenomenon, as the lens acts as a converging element. Ultimately, the discussion highlights the relationship between spherical and plane waves in the context of lens optics and Fourier transforms.
fisico30
Hello,
does anyone know how a converging lens forms the Fourier transform of an aperture when the obs. screen is at distance=f?
If each point emits a spherical wave, the lens should make it then parallel and the FT should be the interference resulting from that.
However, if we decompose the amperture in plane waves, each plane wave will leave be focused to a point in the focal plane.
The latter explanation (plane wave decomp.) is clear but I think the first (spherical wave) is more physically true. Any clarifications or correction to these views? How does this spherical wave interference match the plane wave result?
Science news on Phys.org
I think that the easiest way to understand this is to compute de Fraunhofer (that is: at infinity) diffraction pattern of the aperture. Then, if you realize that a converging lens concentrates all rays coming from a direction to a point in the focal plane, you will see that the lens just brings the diffraction pattern from infinity to the focal plane.
If you use your cornea as converging lens, you can see the diffraction pattern at infinity with your retina. Try to see a distant point source (plane waves) through a very small hole (0.1 to 0.2 mm in diameter).
You are right; you can decompose the aperture in spherical waves but not in plane waves. A plane wave is a complete plane and not a bit of a plane.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
