Frame of reference, Forces, and Angles
The discussion centers on the dynamics of a medallion hanging at an angle inside a moving box, exploring the implications of forces and frames of reference. It is established that if the medallion hangs at a non-zero angle, the box must be a non-inertial frame, indicating that the box is accelerating. The velocity of the box is not constant, and the acceleration is related to the angle of the medallion, expressed mathematically as a = gsin(theta). The conversation emphasizes the need for external forces to maintain the medallion's equilibrium at an angle, contradicting the claim that both velocity and acceleration are zero. Overall, the analysis highlights the relationship between forces, angles, and motion in a non-inertial frame.
PhysicsIdiot
This is more of a concept problem that I'm trying to grasp.
Verbatim from the book:
"A box is moving with a horizontal velocity, v, relative to an inertial frame of reference so that a medallion of mass, m, inside of the box hangs from the roof of the box with an angle, theta, relative to the vertical as shown in Figure F.
http://img165.exs.cx/img165/8100/sitf9nw.jpg
What can be said about the velocity of the box? What can be said about its acceleration? Explain."
I'm thinking, the velocity is constantly changing and the acceleration is constant because there would have to be an acceleration to keep that medallion at the position. What do you guys think?
That's right!
really? my friend from an ivy league school said the velocity was constant and the acceleration was zero... so .. can anyone else confirm which answer is correct?
Your ivy league friend is wrong.
Now, ask yourself (or him), if the medallion hangs with a non-zero angle, gravity will produce a non-zero torque about the attachment point, right?
The only way such a non-zero torque from external forces is compatible with the medallion's stationary position with respect to the box frame, is that the box frame is a non-inertial frame.
is there anyway to prove this mathamatically? like the x component of the medallion?
Your system is a medallion attached to a string.
Net Force = 0.
Fnet = Fg + Ft (Tension)
Fnet = mgsin(theta)+(-mgsin(theta)). This would cancel only if the tension force is applied at the same angle as the gravity force, aka if the medallion is hanging straight down. For the medallion to be hanging at an angle there must be another force in play but keeping the system in equilibrium.
Ft would expand to -mgsin(theta)+(-mgcos(theta)) where the sum of this quantity would equal mgsintheta.
F_{net} = ma
ma = mgsin\theta
a = gsin\theta
Regards,
Nenad
how did you get mgsin"theta"?
The magnitude of acceleration depends on the angle that gravity is pulling you at. Imagine a ball on a ramp. The steeper the ramp, the closer theta is to 90 degrees. From convention you know that a ball rolls down a steep ramp much faster than it would a shallow ramp (theta => 0 degrees).
In the system, the sin(t) means the angle the medallion is hanging at in comparison to where 'straight down' is.
