Free columns-combinations of columns?
  • Thread starter Thread starter sarvesh0303
    Columns
In Gilbert Strang's linear algebra book, pivot columns are defined as those that cannot be expressed as combinations of earlier columns, while free columns can be. The discussion clarifies that "earlier columns" refer to those positioned to the left in a matrix. It explains that free variables can be chosen first to determine the values of pivot variables, as starting with pivot variables may not always yield a solution. An example illustrates that when free variables are prioritized, they can effectively dictate the values of pivot variables, enhancing clarity in the solution process. This approach simplifies understanding the relationship between pivot and free variables in linear systems.
sarvesh0303
In Gilbert Strang's book on linear algebra, he mentions that pivot columns are not combinations of earlier columns and that free columns are combinations of earlier columns. What columns is he referring to by earlier columns?
Also, what property distinguishes pivot variables and free variables that we choose the values for free variables for special solutions. Why don't we choose the values for the pivot variables and then find the free variables?
A is earlier than B means A is to the left of B.
Because it does not always work, starting with the pivot variables. But starting with the free variables always works.
For example, let's say that after Gaussian elimination, you end up with x+y=6, and no equations at all for z and w. X is the pivot variable. y, z and w free. You could start with x, and say y is 6-x, but then what do you do about z and w? But if you do it the other way, then what you do to the free variables tells you all about the pivot variables, too.
On a deeper level, "starting with x" is another way of saying "let x be a free variable". This would correspond to interchanging the columns for x and y to make y pivot and x free.
Thanks a ton. Wow... you just made things so much clearer for me!
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
