Free fall and impact force calculation
Calculating the impact force on screws requires understanding the properties of both the falling object and the surface it impacts. The impact force depends on the duration of the impact; softer surfaces result in longer impact times and lower forces. The weight of the box is 27 lbs, and it is dropped from a height of 5 ft onto a concrete slab. The discussion also explores the difference in impact effects between using 16 screws versus 24 screws in securing the boxes. Ultimately, to accurately determine the impact force on the screws, one must consider the material properties and the area of the screws in relation to the shear modulus.
bama ing
first of all I have a case that is screwed in another case ,I like to know a basic way to calculate the impact force in the screws ,the are 16 screws, I try using the basic impact force formula and the conservation of energy in the free fall,but I am having problems since I don't have the D which apparently its the distance after the impact.The weigh of the box is 27 lbs and its throwed from 5 ft.
It's impossible to know what the impact force is going to be without knowing some properties of the falling object and the surface they are hitting.
The force will depend on the amount of time the impact takes. With softer surface, impact will take longer, and forces will be lower.
thnax,can i incorporate that information to the formula,I mean if I findt hat kind of info
Impact force
I have a 27 pound box attached to a another box by 16 screws in 4 brackets one for every corner,I like to compare the effect of the impact if I put 16 screws or if I put 24(like the number of holes in the bracket).It would be dropped from 5 ft to a concrete slab,the material of the outside box its a TSC composite material.So I think what I need its the impact force that will received the box and that will tranfer to the screws,after that I can divided by the section area of the screws and compare that to the shear modulus,but I am not sure.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
