Solving Free Fall Problem: Initial Speed & Height for Same Time Impact
  • Thread starter Thread starter tlogan
    Fall Free fall
A user seeks help with a physics problem involving two balls: one thrown upward from a building and another dropped one second later. The first part of the problem is solved, yielding an initial speed of 0.2 m/s for the first ball to ensure both hit the ground simultaneously. However, confusion arises regarding the second part, where the user struggles to determine the building's height given specific initial speeds. Clarifications are provided on using the correct equations for both balls, emphasizing the need to account for their different times of flight. The user ultimately arrives at a new initial speed of 9.9 m/s but remains uncertain about its accuracy and seeks further guidance.
tlogan
Hello friends, I am very new to this forum and I´d like to consult you if i have any questions.
Currently I am studying basic physics for my ug.
I´d really apreciate it if you could help me out.
A ball is thrown straight up from the edge of the roof of a building. A second ball is dropped from the roon one second later. You may ignore air resistance.
a) If the height of the building is 20m, what must be the initial speed of the first ball if both hit the ground at the same time.
b) Consider the same situation but now let the initial speed v0 be given and consider the height h of the building as the unknown.
What must be the height of the building for both balls to reach the ground at the same time for each of the following value s of v0 (i) 6 m/s (ii) 9.5 m/s.
I was able to solve a) and i believe that the initail velocity must be 0.2 m/s.
For the second question I have tried for hours but i can't seem to convince myself that this is possible at all. For instance if the ball 1 is in the air, 6 m, and the next second the second ball is dropped with the accelerration -g. How can the ball which has to travel the extra 6 m hit the ground at the same time ball 2 does?
I am thoroughly confused. Please help me.
THanks in advance.
Hi tlogan,
I don't believe this answer is correct. Can you show how you got it?
Hello sir,
all i did was finding the velocity of the second ball.
i used vx²=v0²+2a(x-x0)
Then I put:
Vx² = 2 * -9.8 (-20)
Vx = 19,8 m/s.
THen I put it into the equation x = x0+vo*t+1/2*a*t², for t = 1
20 = Vxo
And then 20 - 19,8 = 0.2 m/s.
However now that u say it, its wrong.
I´ve gone through it but can't really figure out how to tackle this problem. ?
tlogan said:
Hello sir,
Then I put:
Vx = 19,8 m/s.
This is where an error is. The t in this equation is the time of flight of the particle. In other words, the equation answers: if the particle starts at x0 with speed v0, what position x is it at after time t?
But neither of these balls is in the air a total of 1 second, so you would not set t=1. The difference in their time of flights is what is equation to one second.
So instead, what I would suggest is to write out your equation:
twice (once for each ball). Since they have different times, you can use t1 for the time variable in one equation and t2 for the other. As soon as you write out how t1 and t2 are related to each other, you can then solve the set of equations for v0. What do you get?
Hello sir, I really thank you for helping me out.
I got:
sqrt(40/9.8) = 20/Vo
Then I get Vo = 9.9 m/s.
I don't really know if this is the right answer. If it isn't could you please elaborate on the suggestion you made? Because I don't really know whether I fully grasped you idea or not.
Thank you
I got:
I don't believe this is correct. What I was talking about in my last post was using the equation:
For the ball that is being thrown up, what is x, x0, and a? So you can write down this equation for ball 1.
For the ball being dropped, what is x, x0, v0, and t? Write down a separate equation for the second ball.
What two equations do you get? Using those two equations, you should be able to solve for the v0 in the first equation. Do you get the right answer?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
