Free particle has a Gaussian wave packet wave function.
The discussion focuses on solving the wave function for a free particle with an initial Gaussian wave packet described by the equation \(\Psi(x,0)=Ae^{-ax^{2}}\). The solution involves using Fourier transforms and completing the square in integrals. The final wave function is derived as \(\Psi(x,t)=\left(\frac{2a}{\pi}\right)^{(1/4)}\frac{e^{-ax^{2}}}{\sqrt{1+(i2\hbar at/m)}}\). Key techniques include manipulating the exponentials and defining \(\beta = 1 + i2\hbar at/m\) for simplification.
  • Understanding of quantum mechanics principles, particularly wave functions.
  • Familiarity with Fourier transforms and their applications in quantum mechanics.
  • Knowledge of completing the square technique in calculus.
  • Basic concepts of complex numbers and their manipulation.
  • Study the properties of Gaussian wave packets in quantum mechanics.
  • Learn about the Fourier transform and its role in quantum state evolution.
  • Explore the implications of the Schrödinger equation for free particles.
  • Investigate the concept of wave packet dispersion over time.
Students and professionals in quantum mechanics, physicists working on wave function analysis, and anyone interested in the mathematical techniques used in quantum theory.
Agent M27
This is problem 2.22 from D.J. Griffiths Introduction to Quantum Mechanics
A free particle has the initial wave function:
Find \Psi(x,t). Hint Integrals of the form:
\int_{-\infty}^{\infty}e^{-(ax^{2}+bx)}dx
can be handled by completing the square: Let y\equiv \sqrt{a}[x+(b/2a)], and note that (ax^{2}+bx)=y^{2}-(b^{2}/4a).
\Psi(x,t)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{\infty} \phi(k)e^{i(kx-\omega t)}dk
\phi(k)=\frac{1}{\sqrt{2\pi}}\int_{-\infty}^{\infty} \Psi(x,0)e^{-ikx}dx
\omega=\frac{\hbar k^{2}}{2m}
So I found \phi(k)=\left(\frac{1}{2\pi a}\right)^{1/4}e^{-k^{2}/4a}.
Plugging this into my eq for \Psi(x,t) I get the following:
\Psi(x,t)=\frac{1}{\sqrt{2\pi}}\left(\frac{1}{2\pi a}\right)^{1/4}\int_{-\infty}^{\infty} e^{-k^{2}/4a}e^{i(kx-(\hbar k^{2}/2m)t)}dk
=\frac{1}{\sqrt{2\pi}}\left(\frac{1}{2\pi a}\right)^{1/4}\int_{-\infty}^{\infty}exp[-\left(\left(\frac{i\hbar t}{2m}+\frac{1}{4a}\right)k^{2}-ikx\right)]dk
Now here is where I get stuck. I feel like I need to do another completing the square manipulation to argument of the exponential,but I am having trouble seeing how the obtained the following solution:
\Psi(x,t)=\left(\frac{2a}{\pi}\right)^{(1/4)}\frac{e^{-ax^{2}}/[1+(i2\hbar at/m}{\sqrt{1+(i2\hbar at/m)}}
Any help would be greatly appreciated. Seems as though Professor Griffiths has some real cute tricks up his sleeve. Thanks in advance.
Joe
If you pull out a factor of 1/4a in the coefficient of the quadratic term, the exponent will be equal to
$$-\left[\left(1+\frac{i2\hbar a t}{m}\right) \frac{k^2}{4a} - ikx\right]$$ To save you some writing, it would convenient to define ##\beta = 1+ i2\hbar at/m## since that quantity appears in the expression you're trying to derive. So you want to complete the square on
$$-\left(\frac{\beta}{4a}k^2 - ikx\right)$$
Ah ha! Thanks a lot Vela.
  • · Replies 30 ·
