- 3,186
- 3,797
Well, it's that time of year again in New England and discussions are on about freezing water pipes. I'm being told hot water pipes freeze and burst more often than the cold water pipes. Any believers ?
The discussion centers around the phenomenon of freezing water pipes, specifically whether hot water pipes are more prone to freezing and bursting compared to cold water pipes. Participants share personal experiences, anecdotal evidence, and seek a physics-based explanation for the claims made.
Participants do not reach a consensus on whether hot or cold water pipes are more likely to freeze. Multiple competing views remain, with some sharing personal anecdotes that support different sides of the argument.
Participants mention various factors that could influence the freezing of pipes, including insulation, material properties, and environmental conditions. There is also a recognition of the complexity involved in the discussion, with references to anecdotal evidence and the need for controlled investigations.
I don't think so. My cold water pipe in a VERY badly insulated kitchen froze this morning, as it has one or two other times in the past 20 years. My hot water pipes have never frozen.gmax137 said:Well, it's that time of year again in New England and discussions are on about freezing water pipes. I'm being told hot water pipes freeze and burst more often than the cold water pipes. Any believers ?
gmax137 said:Any believers?
As far as I understand things your correct, I remember that water freezing story from way back. I believe that it comes from the practice of leaving your cold water tap dripping which in turn makes the line far less likely to freeze, very few people however leave the hot tap dripping.NukeProf said:There is no physical basis for that conclusion. It must be anecdotal and would never stand up to a controlled experimental investigation.
Ha. Well, I've been reading these forum posts for years and have always enjoyed the discourse. Physics, mathematics and engineering have been my passion for 50 years. It is a first post for sure. The topic seemed so apt in reminding me of a personal disaster, I couldn't help myself. You might be surprised that there is a huge silent majority who visit and devour these entertaining conversations regardless of the level of complexity.gleem said:@cosmicthinker. First post!
Were you just waiting in the wings waiting for an opportunity to make your debut?
I had a similar "disaster" when a wind storm blew out the pilot light on my furnace while everyone was away,over two weeks in freezing weather. I can relate when you mention the damage. In this case both hot and cold lines broke so who knows which went first. I am hoping someone can join in with a "physics explanation" of the mechanics of how hot water would freeze before water of a lower temperature.cosmicthinker said:instances where hot water pipes can and do freeze rather quickly.
I couldn't agree more with that statement.cosmicthinker said:You might be surprised that there is a huge silent majority who visit and devour these entertaining conversations regardless of the level of complexity.
All else being equal, it cannot.1oldman2 said:I am hoping someone can join in with a "physics explanation" of the mechanics of how hot water would freeze before water of a lower temperature.
Hi, my personal experience with freezing pipes after living in Montana (not the tropical part) Is that with the exception of the "PEX" style of waterline once the water reaches freezing no matter what condition the lines, they are going to break. The cost of PEX waterline may be a little high but compared to water damage its cheap insurance, no more PVC or copper lines for me if I can help it.mrspeedybob said:If you live in a climate where freezing is going to be stress that stretches the pipe to the point of failure, I would expect old hot water pipes to fail while the matching cold water pipes were still strong enough to contain the pressure of freezing.
Good forward thinking. This is exactly what happened. All of the old hot water zone pipes fractured, mostly at the many solder joints - 12 solder joints in one such room led to all 12 failing, so the resultant flooding was well distributed as was the resulting interior damage. I could give a good explanation why, but will yield to someone else who hasn't contributed his/her two cents. BTW, the cold water lines froze too, but none ruptured.mrspeedybob said:I would expect old hot water pipes to fail while the matching cold water pipes were still strong enough to contain the pressure of freezing.
I use PEX lines extensively in my business. We shut down for the winter (including all heating) because we own and run a boat marina. We drain the water lines too. It occasionally gets exceptionally cold in Great Lake country and nearly everything, including inland bays that empty into the big lake freeze (not the Great Lake) to more than 2 ft (the ice fishermen love it)! Now PEX doesn't have good heat transfer properties and I don't know if hot water would slowly diffuse away the plasticizer and make it brittle, but just think of a flexible material (equipped with flexible heat radiation vanes) that might substitute for copper vaned lines and be less expensive. They would be exceptionally simple to install and might even outlast copper. Such an invention, if widely adopted, could reap millions! As an old Chemical Engineer and research scientist, I will give this some further thought...1oldman2 said:with the exception of the "PEX" style of waterline once the water reaches freezing no matter what condition the lines, they are going to break.
Thanks Russ, I enjoyed reading the Mpemba link and it pretty well confirms what I was told 50 years ago. Hot water doesn't freeze faster than cold although there are a lot off variables when materials and installation are factored in.russ_watters said:All else being equal, it cannot.
