Frequency Response/Content/stuff
  • Thread starter Thread starter swraman
    Frequency
Frequency content refers to the various frequencies present in a signal, while frequency response describes how a system responds to different frequencies, including magnitude and phase shifts. The transfer function relates the input of a system to its output at specific frequencies. Clarifications indicate that the frequency response function effectively illustrates how a system modifies input signals based on their frequency. Overall, the discussion emphasizes the importance of understanding these concepts in analyzing circuit behavior.
swraman
Hi,
Im a little confused about some concepts dealing with Frequency:
Frequency Content
Frequency Response
Transfer Function
From my understanding:
Frequency content is the content of different frequencies in a signal.
Frequency Response is...not sure
A transfer function tells you the output if a system to an input of a given frequency.
Is my understanding correct?
Thanks
Raman
Frequency
Is a function (in frequency domain) that shows how element properties (Admittance or Impedance for example), a current, a voltage or many other quantities in a circuit varies with frequency.
Transfer Function:
Is a function (in frequency domain) that relates between the input and the desired output in the circuit.
You will find more in:
William Hayt, Engineering Circuit Analysis
I'm not sure about Frequency content.
OK after a little more reading i came to this conclusion:
The frequency Response function tells you how a system treats a given frequency. Eg. the magnitude tells you how much an input signal with the given frequency is magnified by and the phase tells you how much its phase is shifted by.
Is this correct?
Is this correct?
GREAT. You are doing well.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
