Frequency: What is it? Questions about Frequency, Doppler Effect and Mass
  • Thread starter Thread starter okkvlt
    Frequency
okkvlt
Some questions about frequency, doppler effect, and mass.
What exactly is frequency? I know its an intrinsic property, but there are a few things that don't make sence.
How can light waves be stretched out or compressed by the doppler effect if frequency is intrinsic? It makes sense with sound waves- the wave is composed of many air particles, so the wave can be compressed by moving the high pressure and low pressure areas together. But i see no way that an intrinsic property such as frequency can be affected by relative motion.
Also, high frequency photons are high energy, and low frequency photons are low energy. So when light is red shifted, what happens to the missing energy? And when light is blue shifted, where did the extra energy come from? nowhere? The doppler effect makes no sense!
Matter has frequency too. So, if you are moving toward a matter particle, then the frequency of the particle is increasing. And vice versa. So does the doppler effect exist with matter as well?
Another thing:
The energy of a lightwave is given by e=nhf
where n is number of photons, h is Plancks constant, and f is frequency.
The conversion rate of matter to energy is e=mc^2
so, the relationship between mass-energy of a matter particle and light-energy of a photon is mc^2=nhf.
Now think about it. m is to f as h is to c^2.
Why? Because mass and frequency are measures of energy, while h-bar and the speed of light are constants. (n is simply the number of photons, which really doesn't matter because by reducing the number of photons to 1 and increasing frequency you would still see the relation between the energy of a single photon and the energy of a single matter particle of a given mass.)
Does anybody else find this very interesting?
Does this mean there is some kind of relationship between mass and frequency? Perhaps mass and frequency are different manifestations of the same thing.
You probably shouldn't use the relativistic mass when you talk about photons. Use E^2=\vec pc^2+m^2c^4 instead, where m is the rest mass. The reason I don't like the idea of relativistic mass when we're talking about massless particles is that the only way to define it is to put the left-hand side of the equation above equal to "relativistic mass"2c4. That's pretty pointless. That concept makes more sense for massive particles when you can define it as \gamma m.
As for the frequency... Suppose e.g. that you throw a rock into a pond and watch the ripples. If you're in the water, you will se a certain number of peaks pass you in (say) ten seconds, but if your brother is in a balloon above your head, drifting slowly past you with the wind, he will see a different number of peaks pass him in the same time. So you will disagree about the frequency. (Remember that the frequency is just the number of times something happens in a certain time).
Frequency is the the number of "ups" and "downs" that occur per measure of time. It is all relative depending on where you are and how you observe it. Observations of frequency are different at different locations. That is why the Doppler effect works as it does.
Frequency is a measure of the number of occurrences of a repeating event per unit time. The event can be anything.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
