Direction of Friction in Circular Motion: Solving the Record Spin Dilemma
In summary, the direction of friction on an object placed on a spinning record is directly inward, in the same direction as the centripetal force. This is because the object is moving in a circular path and the friction on the record is acting as the centripetal force. The reaction force from the object on the record is negligible. If the record were also accelerating, there would be two perpendicular components of acceleration.
ndogg
24
If an object is placed on a record that is spinning, what is the direction of the force of friction?
Which way is he object accelerating?
Got it now?
The object itself is not accelerating because it remains still on the record. So is there 0 friction?
remember that acceleration is change in velocity per unit time not speed. Velocity has direction involved! This is centripetal acceleration, so the direction of friction is directly inward. Think of riding in a car around a sharp curve.
So the direction of friction is in the same direction as the centripetal force (which is the center of the record)? Shouldn't it be in the opposite direction because there has to be an equal and opposite reaction?
Good question. The object sitting on the record is moving in a circle. Now pretend that the record does not exist, but instead, some arbitrary force holds the object in a circular path. You know that this force must be the centripetal force because if it were not, the object would go off on a path tangent to the circle. This arbitrary force is the friction of the record. Now the reaction force is actually the friction from the object acting on the record, but this force is not great enough to alter the record and is therefore negligible.
So, in this case, friction = centripetal force?
Yes, good job. Just so you know, if the record were actually accelerating with speed too, you would just have two components of acceleration perpendicular to each other, so you can use A squared plus B sq = Csq
Thanks! Problem solved.
1. What is friction in circular motion?
Friction in circular motion is the force that opposes the motion of an object in a circular path. It is caused by the contact between two surfaces and can slow down or stop an object's circular motion.
2. How does friction affect circular motion?
Friction affects circular motion by creating a force that opposes the direction of motion, making it difficult for an object to maintain its circular path. This can result in a decrease in speed or change in direction.
3. What are some examples of friction in circular motion?
Some examples of friction in circular motion include the friction between a tire and the road when a car turns, the friction between a ball and the ground when it rolls, and the friction between a spinning top and the surface it is spinning on.
4. How can friction in circular motion be reduced?
Friction in circular motion can be reduced by using lubricants, such as oil or grease, between the surfaces in contact, using smoother surfaces, and reducing the amount of force applied to the object.
5. Why is friction in circular motion important?
Friction in circular motion is important because it allows us to control the speed and direction of objects in motion. It also helps us to maintain stability and prevent slipping or sliding in circular motion.
