Friction, Kinetic Energy, & Momentum of a Sphere down an inclined plane
A solid sphere of mass 3.00 kg and radius 12.5 cm rolls down a 13.5-degree incline for 250 m, prompting questions about the minimum coefficient of static friction, velocity at the bottom, angular momentum, and kinetic energy. The velocity has been calculated correctly, but there are uncertainties regarding the static friction force and angular momentum calculations. It's noted that the moment of inertia formula used may not be appropriate since the sphere rotates around its center of mass. Additionally, it is clarified that friction does not do work if the sphere rolls without slipping, as the point of contact remains stationary relative to the incline. The discussion emphasizes the need for a clear understanding of forces, torques, and energy conservation in rolling motion.
Zenoture
A solid sphere of mass 3.00 kg and radius 12.5cm rolls without slipping down an incline of
angle 13.5 degree for 250 m. Find the minimum coefficient of static friction required for a
rolling without slipping. What is the velocity of the center of the sphere at the bottom of the
incline? What is the angular momentum at that point? That is the kinetic energy at this point? Make a drawing, show the forces and torques. Indicate the torque which you are using for your calculations. Derive your formulas.
[Figures can all be rounded to 3 sig figs.]
M = 3.00 kg
R = 12.5 cm = 0.123 m
θ = 13.5
d = 250 m
h = d*sinθ = 58.4 m
V = volume = 4/3πR3; dV/dR = 4πR2
ρ = M/V
Icm = ∫r2dm
dm = ρ*dV
ME = Krot + Kcm - U
L=Iaω; Ia = Icm + Md^2 where d is the distance between the two axes
http://dl.dropbox.com/u/22657586/phys130_mt2_f10_num2.JPG
I found the velocity fine, and the answer matched with the solutions, but I can't seem to get the angular momentum, coefficient of friction, or the kinetic energy at the bottom.
For friction...
I know that fs ≤ μs*N & N = Mgcosθ but how do I find out what fs is?
For angular momentum...
I started with the L equation above, then subbed in the values from my previously derived work (see image) but the answer I got was way off from the correct answer.
For kinetic energy at the bottom...
It would just be 7/10*M*v2 minus the work done by friction correct? So if I can somehow find the work done by friction over the distance traveled, then I find the amount of kinetic energy left at the bottom... would that be right?
I know there are a lot of questions here, but since they're all related to the same problem, I thought I would take a shot and just put all the thoughts in my head about this problem and just have the community pick at what they feel they want to attack first, and maybe help me make a game plan for this sort of problem. Thanks in advance for any help given!
Official Answers:
V=28.6 m/s
L=4.39 kg m2/s
μs=0.0686
Hello Zenoture,
Welcome to Physics Forums!
M = 3.00 kg
θ = 13.5
d = 250 m
h = d*sinθ = 58.4 m
ρ = M/V
Icm = ∫r2dm
dm = ρ*dV
ME = Krot + Kcm - U
Okay, so far so good. :approve:
For friction...
You've found the velocity of the ball already. You can use your kinematics equations (for uniform acceleration) to find the ball's acceleration.
The ball is accelerating down the ramp. So the sum of all forces are not equal to zero. The sum of all forces are equal to the ball's mass times its acceleration: Newton's second law. Use your free body diagram for this. What are the forces acting on the ball?
Alternatively, if you wanted to, you could calculate the ball's angular acceleration in the same way (using, in part, the ball's initial and final angular velocity), and then use Newton's second law equivalent in terms of torques. What torques are acting on the ball? Which forces cause torque on the ball?
I suggest working it both ways to double check your answer.
Um, the formula you used for moment of inertia on this part was
Ia = Icm + Md2.
Well, okay. It's not the formula I would have started with, but let's go with it anyway. That formula is for some sort of massive shape (could be a ball) pivoting on a point that is not necessarily the center of mass. For example, it could be a ball attached to one end of a massless rod, and the whole thing pivots at the other end of the rod.
So let's apply it to this problem. What is the pivot point of the ball? Is it not already rotating around its center of mass? If it is already rotating around the center of mass, what does that tell you about d in the formula?
You've already calculated the ball's moment of inertia, Icm = (2/5)Mr2.
Later in your handwritten work, you seem to be implying that ω = R/v. That's not right. ω = v/R. Just remember that the angular velocity is proportional to the linear velocity.
Friction doesn't do any work, unless the ball start's sliding.
If the ball is not sliding, then the part of the ball that is touching the ramp is stationary with respect to the ramp (that's kind of the definition of not sliding). So the distance of the slide is zero, meaning the work done by friction is zero.
Official Answers:
V=28.6 m/s
L=4.39 kg m2/s
μs=0.0686
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
