Friction On 2 Blocks + Angled Pull
47 replies · 8K views
ok so I've changed ƩFyb = 0 = NB + 2×axsin15 - mb×g
which decreases the normal.. i understand that now.. i didnt understand that before because i was thinking that only the x portion of the Force applied was acting on B. Now by realising the Y component of F also acts on B i can see how it reduces the normal.
So subbing into Fx of B i get an acceleration of 2.389s.
and subbing that into Fx equation for Block A i get 49.64N... is this correct?
The zero on the left of the equation is correct and the -mbg on the right is correct.
However, the y-component of NB is not NB. You're going to need a trig function to get the y-component. (Study the free body diagram.)
I don't know how you got the term 2×axsin15. This term should represent the y-component of the friction force fB which will be fB sin15.
You can then use fB = μsNB to write the y-component of fB as μsNBsin15. So, your equation [itex]\sum[/itex]Fy = 0 will be an equation with just one unknown, NB. Therefore you can find the value of NB.
Then, you can set up [itex]\sum[/itex]Fx = max for block B and find the acceleration.
These answers are not correct, but they are not too far off.
why is it not Nb, the normal is perpendicular to the incline surface? 2×axsin15 is the vertical component of F acting on B? or does only the horizontal portion of F work on B? how does friction come into action at all on the y-axis? I've changed the co-ord system when dealing with B. should i have not done that or something?
Remember, we are choosing the y-axis vertical; that is, the y-axis is perpendicular to the ground and not perpendicular to the incline. Look at the attached figure and you can see that NBy is not the same as NB. Using trig on the right triangle you get
NBy = NBcos(15)
The figure also shows the y-component of the friction force, fBy. You can see that fBy = fBsin(15).
Since block B is on the verge of slipping, you can write fB = μsNB. So, that means
fBy = fBsin(15) = μsNBsin(15)
You also know that the y component of the weight is
Wy = -mg
There is no y-component of acceleration, so Newton's 2nd law gives [itex]\sum[/itex]Fy = 0. That is,
NBy + fBy + Wy = 0.
Substitute for each of these terms using the red-colored expressions above and solve for NB.
Ok so using the above method i get Nb = 17.481, subbing into fxb i get ax = 2.529m/s^2 then subbing into Fxab i get 50.48N
Yes, that looks correct. You can now easily calculate the value of the friction force fB.
I don't believe those values are correct. You didn't show your work so I can't see where you went wrong.
Did you try setting up Newton's 2nd law for the x-component of the forces for block B?
You have the equation [itex]\sum[/itex]Fx = fBx + NBx + Wx = mBax.
Use the free body diagram for B to get expressions for the x-components of the forces and then use the equation to solve for ax.
Ok so Nb = 17.481
Fxb = 2*-ax = 17.481cos15 -2gsin15 + 10.4886cos15
so ax = -4.0422
Now subbing into fxab
F = 59.88N
sandman203 said:
Ok so Nb = 17.481
We have chosen the positive direction of the x-axis to be to the left since we know that the blocks will accelerate to the left. Then ax will be a positive number. You should not put a negative sign in front of ax in the equation.
Note that NB has an x-component that is negative. Also, are you sure you used the correct trig function to get the x-component of NB? The x-component is the side opposite the 15 degree angle in the right triangle.
The weight force acts entirely along the negative y-axis. So, what is the x-component of the weight?
You have the correct expression for the x-component of the friction force.
Ok so the x component of Wy = 0. So fxb = 2*ax = -17.481sin15 + 10.4886 cos15
so ax = 2.803m/s^2
& then F = 52.126N
Acceleration is correct.
F is not correct. Please show your work.
Ok so NA = 7×g - Fsin30
so FfA = 0.6 × (7×g - Fsin30)
Now Fx = m×ax = Fcos30 - FfA
From before ax = 2.803 & FfA = 0.6 × (7×g - Fsin30)
so Fx = 7×2.803 = Fcos30 - ((0.6 × 7 × g) - (0.6 × Fsin30)
Fx = 19.621 = Fcos30 - ((0.6 × 7 × g) - (0.6 × Fsin30)
Fx = 19.621 + 41.46 = Fcos30 + 0.6×Fsin30
Fx = 60.881 = F (cos30 + 0.6sin30)
Fx = F = 60.881 / (cos30 + 0.6sin30)
F = 52.21N?
So i got this second time around.. I am not sure if i subtract FfA or add it. Adding i get F = 38.053
That all looks very good! However, did you use the correct coefficient of friction?
hmmmm 0.6? aren't we trying to overcome the static friction? I am not sure how i'd incorporate Kinetic friction because isn't the question asking the force needed to make the block slide from rest?
We're trying to produce enough acceleration of A so that B will slip on A. Acceleration of A implies that A is slipping on the floor. So, you need to use the coefficient of kinetic friction for the friction between the floor and A.
[I didn't see where the problem stated the system starts from rest. If so, then you should check that the force necessary to overcome the static friction between A and the floor is not greater than the force required to accelerate the system at 2.80 m/s2 once A starts sliding. But you can check that the force that is just sufficient to start A slipping is not enough force to accelerate the system at 2.80 m/s2. So, applying just enough force to start A sliding would not cause B to slip on A.]
Ah ok, yes the question does not state that block A is at rest. I am going to go with the 0.4 co-efficient because u guys are way smarter than me. But can acceleration not imply that a body is being accelerated from rest? Anyways thanks a **** tonne for the help TSny, must of been a pain dealing with me lol.
so FfA = 0.4 × (7×g - Fsin30)
so Fx = 7×2.803 = Fcos30 - ((0.4 × 7 × g) - (0.4 × Fsin30)
Fx = 19.621 = Fcos30 - ((0.4 × 7 × g) - (0.4 × Fsin30)
Fx = 19.621 + 27.44 = Fcos30 + 0.4×Fsin30
Fx = 47.061 = F (cos30 + 0.4sin30)
Fx = F = 47.061 / (cos30 + 0.4sin30)
F = 44.14N please tell me this is finally correct!
That's what I got. So, I believe it's correct. Good work!
wow ok finally haha. guess we will see when it gets marked! thanks once again for the help dude realllllllllllly appreciate it!
