Friction pinning a block on another block
  • Thread starter Thread starter richard karn
    Block Friction
The discussion revolves around calculating the minimum horizontal force required to prevent a smaller block from slipping down a larger block, given their respective masses and the coefficient of static friction between them. The smaller block weighs 36 kg, while the larger block weighs 98 kg, with a frictionless surface beneath it. Participants note the absence of a figure that is crucial for visualizing the problem. Additionally, there is an emphasis on the necessity of posting an attempt at solving the problem to facilitate constructive feedback. The conversation highlights the importance of understanding the forces at play in this friction-related scenario.
richard karn
The two blocks (m = 36 kg and M = 98 kg) in the figure below are not attached to each other. The coefficient of static friction between the blocks is µs = 0.48, but the surface beneath the larger block is frictionless. What is the minimum magnitude of the horizontal force vector F required to keep the smaller block from slipping down the larger block?
hmm, where's the figure? and also you are supposed to post an attempt to the solution..
