How Do We Calculate the Weight of Block C in a Frictional Force Problem?
  • Thread starter Thread starter Redcutter
    Forces
The discussion focuses on calculating the weight of block C in a frictional force problem involving blocks A and B. Both A and B weigh 27.5N, with a coefficient of kinetic friction of 0.40, and block C descends at a constant velocity. The user successfully determined the tension in the ropes connecting the blocks, concluding that T1 is 11N and T2 is approximately 17.60N. Using these tensions and the equations of motion, the user derived the weight of block C to be around 36.3N. The calculations are confirmed to be correct, emphasizing the importance of equilibrium in the system.
Redcutter
Hello, I'm new here. I've browsed before and saw that this is a very helpful community, so I came here for assistance.
Blocks A, B, and C are placed as in the figure and connected by ropes of negligible mass. Both A and B weigh 27.5N each, and the coefficient of kinetic friction between each block and the surface is 0.40. Block C descends with constant velocity.
Image attached:
http://session.masteringphysics.com/problemAsset/1038585/38/YF-05-56.jpg
What is the weight of block C?
I've found the first part of this problem, which is the tension holding A and B, which is 11N. Part C has me confused. Here's my attempt:
Block B
∑FY=
NB-mBgsin(36.9)=0
NB=27.5Nsin(36.9) = 16.5115562
fK= µNB = .40(16.5115562)= 6.604622479∑Fx=
T2-T1-fK- 27.5cos(36.9)= 0
T2-T1-6.604622479- 21.99132811= 0
T1= 11N
T2-11-6.604622479- 21.99132811= 0
T2= 17.59595059N.
Block C
∑Fx= T2-mCg = 0
T2 = mCg = 17.59595059N
Is this correct?
Thanks in advanced.
Since the system is not accelerating, \sumF=0.
F1=.4*mg=.4*27.5N
F2=.4*mg*sin(36.9 degrees) = .4*27.5*sin(36.9) N
therefore
F1 + F2 = mg (m = mass of block 3)
.4*27.5(1+sin(36.9)) = mg (the weight of block 3)
O M = opposite to the movement
Block a:
F in a = F friction in a = N.u = 27,5u O M
Block b:
F in b = Pb sin36,9° and Pb cos36,9°u O M = 27,5.3/5 and 27,5.4/5.u
F friction = 27,5 . 3,6/5 > 27,5.3/5 so they have same direction
27,5.6,6/5 = C = 5,5.6,6 = 36,3N
Thanks, guys.
