DaveC426913
2025 Award
- 24,623
- 8,970
This is good. I have not been acquainted with 'shear' stress and 'normal' stress, but now that you're described it, I can very easily understand why water can 'slide" even while being incompressible. They're two different properties.Dale said:You are mixing up two different, but related, topics. What makes something compressible or not is that a compressible material's normal deformation is proportional to its normal stress. What makes a fluid flow is that its shear deformation rate is proportional to its shear stress.
So the difference between a compressible gas and an incompressible liquid is in its behavior under normal stress. They behave the same under shear stress. So a fish in a sealed container can swim just fine, by applying shear stress to the water, as always.
I had been thinking of these tile puzzles:
They slide past each other easily enough but they will not compress - one tile always takes up the same area (volume).
