Function notation and shifting functions
The discussion centers on the modeling of a particle's velocity using two different stopwatches. When X starts their stopwatch, the velocity is represented as ##\vec{v}(T)##, while Y starts theirs after a time delay, leading to the question of whether to use ##\vec{v}(t)## or a new function like ##\vec{u}(t)##. It is clarified that if the function arguments are consistently defined, ambiguity is avoided; however, introducing a new function is necessary to accurately represent the second stopwatch's readings. The relationship between the two functions is established as ##\vec{u}(t) = \vec{v}(T)##, ensuring correct behavior when calculating values. This approach allows for clear differentiation between the two time references in the modeling of velocity.
PFuser1232
Suppose two people, X and Y, have two different stopwatches. X starts his/her stopwatch as some particle passes an origin. We can model the velocity of the particle by ##\vec{v}(T)##, where ##T## is the reading on the first stopwatch. After an amount of time ##\Delta t##, Y starts his/her stopwatch (##T = t + \Delta t##). Is it correct to model the velocity of the particle as ##\vec{v}(t)## where ##t## is the reading on the second stopwatch? Or should we change the letter used to represent the function [to ##\vec{u}(t)## for example]?
Mathematics news on Phys.org
It depends. If you are always using ##\vec{v}(T)## and ##\vec{v}(t)##, then there is no ambiguity. But if somewhere you are to write something like ##\vec{v}(0)##, then it is not clear which time you are referring to.
I think it's because the argument of the function ##\vec{v}## as defined earlier always represents the reading on the first stopwatch. To represent velocity in terms of the reading on the second stopwatch a new function is forced upon us such that ##\vec{u}(t) = \vec{v}(T)## for all ##t##. Is this correct?
That equation looks correct. Since ##T = t + \Delta t##, you recover the correct behavior, e.g.,
\vec{u}(0) = \vec{v}(\Delta t)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
