Understanding Function Properties: Solving f(x) Equations for Homework
  • Thread starter Arman777
  • Tags
    Function
In summary, the author is trying to solve a problem involving the equation f(x) = y, but is getting stuck. After some thinking, he comes up with the solution that f(x) + f(16/x) = 16.
Arman777
Insights Author
193
##f(xy)=f(x)+f(y)## and ##f(16)=16##, ##f(2)=?##
function properities
##f(x)=y## so
##f(xf(x))=f(x)+f(f(x))##
then I put
##xf(x)=16##
and
##f(x)+f(f(x))=16##
but this not much make sense,
I am really stucked
What about ##f(4)##?
I don't know,where should I put it ?
Think about it!
PeroK said:
Think about it!
I am thinking,I didnt understand where it will lead. ##f(4f(4))=f(4)+f(f(4))## so ?
Why are you taking ##f(f(x))##?
what's that mean ?
f(16) = f(2*8) = f(2) + f(8) ...
I found that but ıts not going further.And from ##xf(x)=16## and from ##f(x)+f(f(x))=16## you said , ##f(x)+f(16/x)=16##
so ##f(4)=8## and ##f(2)+f(8)=16## but we can't find ##f(8)## and also,I think we can't do these steps cause, we said ##f(4)=8## but we know that
##xf(x)=16## so ##4f(4)=32≠16##.
simply ##f(x)+f(16/x)=16## this is only true for an special ##x## not all ##"x"## s
You should NOT be assuming that ##\ y = f(x)\ ## in the above statement.
The author of this question might just as well have stated this as follows:
##f(ab)=f(a)+f(b)##​
Aa examples,consider the following:
##f(35)=f(5)+f(7)##
##f(9)=f(3)+f(3)##
##=2f(3)##​
function properties
##f(x)=y## so
then I put
##xf(x)=16##
and
##f(x)+f(f(x))=16##
I am really stuck ed
##f(16)=f(2)+f(8)=16##
##f(8)=f(4)+f(2)##
and ##f(4)=8## so,
##f(8)-f(2)=8##
##f(8)+f(2)=16##
##f(2)=4##
Still awkard..there must a solution which we can assume ##y=f(x)## and then solve it
You should not assume that for the statement of this problem.
Ok,thanks..I am trying to solve this for like hours by using ##y=f(x)## ,which I was wrong
It's difficult to help any more without giving it away. Anyway, here's a bit hint: ##4 \times 4 = 16##.
Likes Arman777
Thanks
Arman777 said:
##f(4 \times 4) = f(16)##
oh I see yeah..Thanks again
I think @PeroK was trying to get you to answer his previous question: "What is ƒ(4) ?"
Likes PeroK
İts 8 I found it ?
Arman777 said:
İts 8 I found it ?
There is a more direct path to finding f(4):
ƒ(16) = ƒ(4⋅4) = ƒ(4) + ƒ(4) = 2⋅ƒ(4)
ƒ(4) = ƒ(16)/2 = 8
You might similarly consider how ƒ(x2) is related to ƒ(x), etc.
What are function properties?
Function properties refer to the characteristics or attributes of a mathematical function, such as its domain, range, and behavior.
Why is it important to understand function properties?
Understanding function properties is important because it allows us to analyze and manipulate functions in order to solve equations and make predictions about their behavior.
What does f(x) stand for?
f(x) is a common notation used to represent a function, where "x" is the independent variable and "f" represents the output or dependent variable.
What are some common methods for solving f(x) equations?
Some common methods for solving f(x) equations include substitution, elimination, graphing, and using algebraic properties such as the distributive property and combining like terms.
How can I use function properties to check my homework answers?
You can use function properties to check your homework answers by plugging in the given values for the independent variable and verifying that the output matches the given solution. You can also use a graphing calculator or online graphing tool to visually confirm the solution.
