Functions 12U - Basic Polynomial questions
The discussion centers on solving two polynomial equations. In the first problem, the initial equation is corrected from 1008 to 504, leading to the polynomial 2016 = x^3 + 25x^2 + 150x + 500. Participants emphasize the importance of correctly handling the division and multiplication when rearranging the equation. For the second problem, factoring is suggested using the substitution u = x^2, simplifying the process. The conversation highlights the need for careful attention to detail in polynomial manipulation and solving techniques.
joeseppe
Problem One
1008 = [(10+x)(10+x)(5+x)] / 2
Solution Attempt
5004=[(10+x)(10+x)(5+x)]
5004= (100+10x+10x+x^2)(5+x)
5004= 500 + 50x + 5x^2 + 100x + 20x^2 + x^3
5004 = x^3 + 25x^2 + 150x + 500
0 = x^3 + 25x^2 + 150x - 4504
Where do I go from here?
Problem Two
Solve.
x^4 - 10x^2 + 16 = 0
Solution Attempt
I have no idea on this one. What kind of factoring can i use when the first and second parts are ^4 and ^2 respectively, with the last part being a regular number?
Thanks in advanced guys, I know it's probably something little I'm overlooking :)
For the second one factor it like it was u^2-10u+16 where u=x^2. For the first one, I think there may be multiple mistakes. How did 1008 turn into 5004?
Alright, thanks for the help :)
Typo on the first one, let me try again ;)
Problem One
Solution Attempt
504=[(10+x)(10+x)(5+x)]
504= (100+10x+10x+x^2)(5+x)
504= 500 + 50x + 5x^2 + 100x + 20x^2 + x^3
504 = x^3 + 25x^2 + 150x + 500
Problem One
Solution Attempt
Again you are making mistakes. Remember its a divide by two on the RHS. So when you shift it to the LHS, it becomes a multiply by two. It thus becomes 1008*2 and NOT 1008/2.
Then, do you know how to factorize third degree polynomials?
Righto I missed that one, so the next lines should be:
0 = x^3 + 25x^2 + 150x -1516
Then I would just use factor theorem to solve for x, does that work out in this case?
solve slowly...dont need to hurry... don't make so many mistakes
(10 + x)*(10+x)(5+x) = (5+x)(x^2 + 20x + 100) = 5x^2 + 100x + 500 + x^3 + 20x^2 + 100x
= x^3 + 25x^2 + 200x + 500...check it!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
