How Does a Function on Manifolds Change When Transferred from M to N?
Icosahedron
Assume you have two manifolds M and N diffeomorphic to another. Also, there is a real-valued function f defined on M.
What happens with f when you go from M to N? How is f related to N?
thanks
If you have a map from M to N does the map not also act on the function f and transform it appropriately?
What actually does diffeomorphic really mean?
Take a manifold M without Riemann structure defined on, i.e. without any geometric properties, so that makes it very malleable.
Is not every manifold diffeomorphic to M already M?
If my manifold M can be a ball, a cigar or what have you, what then is a to M diffeomorphic manifold N?
Consider the diffeomorphism g:M-->N.
Then you have that the composition of g^-1 and f, maps from N to R. Is that what you are looking for?
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
