Fundamental Theorem of Calculus
The discussion revolves around the application of the Fundamental Theorem of Calculus, particularly in evaluating definite integrals and understanding their implications in a given problem context. Participants are attempting to clarify their understanding of how to apply the theorem to specific parts of the problem.
  • Participants discuss the validity of taking anti-derivatives and the correct application of the theorem. Questions arise about the interpretation of definite integrals and the significance of evaluating them at specific points, such as F(5).
There is ongoing exploration of the problem, with some participants expressing confusion about the application of the theorem and the nature of the integrals involved. Guidance has been offered regarding the use of the theorem, but no consensus has been reached on the specific steps to take for parts b and c.
Participants note that the problem includes multiple parts and that the original poster has provided limited information about the equations and context, which may be impacting the clarity of the discussion.
ralfsk8
All this information is in the attached file.
What I tried to do was take the anti-derivative of the first equation and plug in the number 5. I'm not sure if that was the way to go so I then just plugged in 5 off the get-go and got 13. Not sure what the question is asking and I would appreciate some guidance.
Thanks
Thanks
If you have concluded that F(5) = 13, then no, that is incorrect. For that part you should NOT attempt to get the antiderivative.
So the anti-derivative is only applicable to parts b and c?
You should not attempt to get the antiderivative in any of the three parts. For part b, you'll need to use the Fundamental Theorem of Calculus. Note that there are two parts of this theorem.
The book says to use the second part of the theorem but I'm not seeing how it would work in this question. Do I plug in the x in place of t?
You're talking about part a, right? What definite integral is represented by F(5)?
√5^2 + 144?
ralfsk8 said:
√5^2 + 144?
No.
Show me what the definite integral looks like. If you quote this post you should be able to reuse this integral.
$$F(5) = \int_?^? \sqrt{t^2 + 144}~dt $$
Mark44 said:
No.
$$F(5) = \int_5^5 \sqrt{t^2 + 144}~dt $$
Is it that?
Yes. Now, what is the value of that integral? That is what F(5) equals. Don't overthink this.
ralfsk8,
In general, what does the definite integral,
[itex]\displaystyle \int_{a}^{b}\, f(x)\,dx[/itex]​
represent?
Mark 44 - I would say either 13 or 0, but as you mentioned earlier, 13 isn't the answer.
SammyS - The area under the curve bounded by the x-axis of a graph and 2 vertical lines (a and b)
What are the vertical lines for this integral?
The vertical lines for this integral are 5 and x
That's for F(x). You're trying to determine F(5). So what are the vertical lines now?
An easy way to remember the fundamental theorem is to consider :
Let :
[itex]F(x) = \displaystyle \int_{b(x)}^{a(x)}\, f(t)\,dt[/itex]
Then :
[itex]\frac{d}{dx}F(x) = \frac{d}{dx} \displaystyle \int_{b(x)}^{a(x)}\, f(t)\,dt = f(a(x))a'(x) - f(b(x))b'(x)[/itex]
It's simply a plug and play formula.
Mark44 - The vertical lines are now 5 and 5. So we're not trying to calculate the area of anything if it's the same line?
Zondrina - Ah yes, that does seem familiar to me
Mark44 - I would assume 5 to 5 which would make it the same line right?
Also think about this F(5) thing, it's MUCH easier than it looks. Imagine you're integrating from one line a to another line b. What if those two lines are the same? Then there really is no area between them right?
A simple example is to consider :
[itex]\int_{z}^{z}xdx[/itex]
Where z is ANY real number or function or anything really, but to keep it simple let z = 1,2,3... and notice no matter what you're going to get the same answer. Then come back to your F(5) question.
Right. So F(5) = ?
Okay so I've narrowed it down to either 0 or 5...
What's your reasoning for each of these?
Well just like Zondrina said, if both of the vertical lines have the same value, then there shouldn't be area, deeming it 0.
As for the 5... I actually have no clue
OK, then what's your answer for F(5)?
My final answer is 0.
Right.
Now, what about parts b and c?
Do I take the anti-derivative and plug in 5?
No you use that plug and play i posted on the first page. Memorize it as it is your best friend to solve questions like these within a minute.
No. Here's what I said back in post #4.
IMHO, memorizing that formula is NOT a good idea, especially if that memorization comes at the expense of understanding.
