Future possibilities of Planetary society's solar sail idea.
The discussion centers on the potential applications of solar sails, particularly in deflecting asteroids and comets away from Earth, and propelling spacecraft to interstellar destinations using focused beams of light. While these concepts are theoretically possible, their efficiency remains a significant concern. The Planetary Society's previous solar sail mission did not meet its objectives, raising questions about the viability of such technologies. Solar sails could potentially allow spacecraft to travel beyond the outer planets using sunlight, but the timeframes involved would be extensive. Overall, while the technology holds promise, practical implementation and efficiency are critical challenges that need to be addressed.
Monsterboy
I don't know how long this solar sail idea has been here , the Planetary society's second solar sail failed to achieve its objective right ? I am interested in the applications of this technique.
1) Is it possible to use them to deflect large asteroids and comets away from the Earth ?
2) Is it possible to propel a spacecraft with solar sail using a powerful laser or some other kind of focused beam of light to interstellar destinations ? even though it might take a long time to reach there.
3) Is it possible to propel it beyond , say Jupiter, Saturn just by sunlight ?
Have you checked the wikipedia article? It answers most of those questions.
All those things are possible*, but their efficiency is questionable.
*even the Pioneer and Voyager probes and New Horizons will reach interstellar distances eventually, but they'll need hundreds of thousands of years for that.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
