Gage Pressure, Absolute Pressure - Gage in Different Environment Problem
  • Thread starter Thread starter lizzyb
    Absolute Pressure
A gage connected to a tank shows a fluid pressure of 42 psi above atmospheric pressure. When the air pressure in the chamber is reduced to a vacuum of 25 inHg, the absolute pressure of the fluid remains unchanged. Calculations indicate that the gage pressure should be 54.3 psi, but there is confusion regarding the correct relationship between atmospheric pressure and chamber pressure. The discussion highlights the ambiguity in the problem statement, which fails to specify whether the 25 inHg is absolute or gauge pressure, leading to misinterpretation. Clarifying the pressure types is essential for accurate calculations and understanding.
lizzyb
State the Problem
A gage is connected to a tank in which the pressure of the fluid is 42 psi above atmospheric. If the absolute pressure of the fluid remains unchanged but the gage is in a chamber where the air pressure is reduced to a vacuum of 25 inHg, what reading in psi will then be observed.
Related Equations, etc
Code:
P    = P    +  P                 (1)
 abs    atm     gage
Answer in back of book: 54.3 psi
Standard atmosphere at sea level: 14.696 psia (29.92 inHg)
Work Done So Far
1) Determine the absolute pressure using P_atm = 14.696 and P_gage = 42 psi
Code:
P    = 14.696 + 42 = 56.696 psia
 abs
2) P_chamber = 25 * 14.696 / 29.92 = 12.279 psi
and manipulating (1) a bit:
Code:
P     = P    - P        = 56.696 - 12.279 = 44.417
 gage    abs    chamber
Which isn't correct; how can I use equation (1) to determine P_gage correctly?
I suppose my problem is not having the correct relationship between P_atm and P_chamber; should I use:
Code:
P    = P     - P        = 14.696 - 12.279 = 2.417   (2)
 atm    atm     chamber
P     = P     - P    = 56.696 - 2.417 = 54.279
 gage    abs     atm
but how do I justify equation (2)?
lizzyb: It currently appears to me your answer, 44.417 psi (gauge), is correct and the back of the book is wrong. I will be glad to hear from anyone if I am currently misinterpreting.
Thank you for your help.
Reading that section of the chapter again I noted the sentence:
Finnemore & Franzi said:
If the pressure is below that of the atmosphere, we call it a vacuum, and its gage value is the amount by which it is below that of the atmosphere.
So translating the statement to math:
Code:
P        = P    - P         => P         = P       - P
 chamber    atm    chamber      chamber     atm       chamber
 gage                                                 gage
                                      = 14.696  - 12.279
                                      = 2.417
 gage    abs    chamber
I think the wording of the question could be improved.
The cited Finnemore quotation doesn't preclude using absolute pressure. Vacuum is reported three ways; e.g., 85 kPa (absolute), 85 kPa (gauge), or -85 kPa (gauge). All three methods are clear if the pressure is followed by the string "(absolute)" or "(gauge)," per the SAE, ASTM, and IEEE requirements.
The problem statement is ambiguous because the authors violated SAE TSB-003 and IEEE/ASTM SI10 requirements by not writing "25 inHg (absolute)" or "25 inHg (gauge)." But current evidence slightly points toward a chamber pressure of -25 inHg (gauge); i.e., 16.665 kPa (absolute).
