How is the Rotational Velocity of Galaxies Measured?
In summary, astronomers use telescopes to measure the rotational velocity of galaxies. They do this by measuring the red/blue shift of stars moving near the galactic plane. If the object is not resolved, they can use spectroscopy to determine the rotation rate.
ChrisVer
464
I was wondering, how can we measure the rotational velocity of a galaxy?
In practice knowing the mass distributions and so on, we could calculate it by classical mechanics (or maybe GR). However people measured the rotational velocity of the galaxies and found that it doesn't correspond to the expected curve (DM or MOND). How did they do it? In a telescope I have the feeling that a galaxy appears as a single dot -1 dimensional object (impossible to see whether it's rotating or not).
Astronomy news on Phys.org
Doppler measurements relating red/blue shift of stars moving near the galactic plane. Naturally, your instrument must have enough resolution to perform such measurements.
Likes ChrisVer
The answer is given by Orodruin, but I want to amend something to it. In fact our telescopes (the ones that astronomers use) are of sufficient resolution such that quite many galaxies will actually be resolved. Have you seen the pictures by HST? Many of those show explicitly that we can see spiral galaxies, or others etc.
I think you are thinking of stars when you think that a galaxy will simply appear as a dot. It is far harder to resolve a star in our own galaxy than it is to resolve a nearby-ish galaxy. We can look at the angular resolutions needed. Let's take a typical star like our Sun and put it at the distance to our nearest neighbor star, Alpha Centauri, which we will just say is 4 light years. The angle subtended by this star is roughly (in radians) ##\theta\approx R_{sun}/(4 ly)\approx2\times 10^{-8}## this is ~.002 arc seconds. A typical (non-dwarf) galaxy is ~100,000 light years across, and let's place it at a distance of perhaps 100 million light years (this is ~10 times farther out than our local group). This gives an angle subtended of ##\theta\approx 100000ly/100000000ly\approx 10^{-3}## which is ~4 arc minutes.
As you can see, it is FAR easier to resolve a nearby galaxy than it is to resolve a nearby star.
In addition, even if the object appears at a dot (unresolved), we can STILL figure out something about its rotation by the spread of the emission/absorption lines that we see in the spectra. Because part of the object will be going towards you, and part of the object will be going away from you, this will produce a spread in the usually quite sharp emission and absorption lines. So, by using spectroscopy, we can in fact figure out rotation of an object, even if we can not resolve that object. We do this quite often for stars actually.
Of course, this will depend on the angle at which we are viewing these objects! So if you are unable to resolve the object to confirm that you are looking at it perpendicular to the axis of rotation, you can only use this as a lower bound on the rotation rate.
Likes Damo ET and ChrisVer
Yes, this. I've actually done it before with radio telescopes. My team collected Doppler shifts from neutral hydrogen clouds from a section of the galactic plane, calculated distances and orbital speeds, and plotted those. Fascinating stuff.
Great question! Measuring the rotational velocity of a galaxy is a complex and ongoing area of research in astrophysics. There are a few different methods that scientists use to measure the rotational velocity of galaxies, and each has its own strengths and limitations.
One of the most common methods is called the rotation curve method. This involves using spectroscopy to measure the Doppler shift of light emitted from stars in the galaxy. As the stars rotate around the center of the galaxy, their velocities will change depending on their distance from the center. By measuring the Doppler shift of the light, scientists can determine the rotational velocity of the stars at different distances from the center of the galaxy. This method is useful because it can be applied to galaxies at different distances from Earth, allowing for a broad range of observations.
Another method is called the Tully-Fisher relation, which uses the luminosity and width of the 21-cm line in the galaxy's hydrogen gas to estimate its rotational velocity. This method is particularly useful for measuring the rotation of spiral galaxies.
Other techniques include using gravitational lensing, which involves observing the bending of light from background galaxies by the gravitational pull of the foreground galaxy, and using the motions of satellite galaxies around the main galaxy to infer its mass and rotational velocity.
However, as you mentioned, these measurements have revealed discrepancies between the expected rotational velocity and the observed rotational velocity. This is known as the "galaxy rotation problem" and it is still an area of active research. Some scientists propose that there may be unseen matter, such as dark matter, contributing to the gravitational pull and affecting the rotational velocity. Others suggest that our understanding of gravity may need to be modified, as in the case of the Modified Newtonian Dynamics (MOND) theory.
Overall, measuring the rotational velocity of galaxies is a complex and ongoing process, and it is an exciting area of study that continues to push our understanding of the universe.
Related to How is the Rotational Velocity of Galaxies Measured?
1. How do scientists measure the rotation of galaxies?
Scientists use a technique called spectroscopy to measure the rotation of galaxies. This involves observing the light emitted by stars and gas in the galaxy and analyzing the Doppler shift, which can indicate the speed and direction of the rotation.
2. What is the significance of measuring galaxy rotations?
Measuring galaxy rotations allows scientists to better understand the structure and dynamics of galaxies. It can also provide insights into the distribution of dark matter, which is thought to play a crucial role in shaping galaxy rotations.
3. What tools and instruments are used to measure galaxy rotations?
Scientists use a variety of instruments to measure galaxy rotations, including telescopes equipped with spectrographs, radio telescopes, and space-based telescopes like the Hubble Space Telescope. They also use computer simulations and mathematical models to analyze the data.
4. Can galaxy rotations change over time?
Yes, galaxy rotations can change over time due to interactions with other galaxies, mergers, and the influence of dark matter. However, the changes are usually very gradual and can only be observed over long periods of time.
5. How does the measurement of galaxy rotations support the theory of gravity?
The measurement of galaxy rotations supports the theory of gravity by confirming the predictions of Newton's laws of motion and Einstein's theory of general relativity. By studying the rotation of galaxies, scientists can also test and refine these theories and gain a better understanding of the fundamental forces that govern the universe.
  • Astronomy and Astrophysics
