Galileos idea and the unknown phenomenon.
  • Thread starter Thread starter narbij
    Idea Phenomenon
narbij
Galileos idea of a fixed value for the gravitational acceleration on the Earth iss now accepted for most pratical calulations allthough variations in the Earth's crust mean that this value is not precisely uniform. However there is another phenomenon that will affected the decent of the cannon balls. If the cannon balls were made of a very light material there would be a very noticble difference in the fall time for different sized balls.
Why is this?
Please involve calculations if possible. I would much appreciate any form of help.:smile:
If you think of something as a point mass, in an environment with no fluid resistance, then any mass's, large or small, experiencing the same gravitational pull, will accelerate and thus fall at the same rate.
When you introduce fluid resistance, ie air resistance, you get two things happening. Firstly, obviously, you get the larger (surface area wise) objects being slowed more and secondly you get terminal velocity limiting the speed of the object.
Calculation wise Newton tells us:
{v^2} = {u^2} + 2as
Thus if initial velocity, displacement and acceleration are equal for all objects, regardless of mass, final velocity will be the same as well.
In terms of air resistance, the equations differ for different shapes. For a sphere of diameter D the initial equation is the following:
F(v) = -c1v - c2v *|v| (sorry still gettin used to tex, c1 and c2 are constants )
These constants are experimentally determined and have the following values:
c1 = 1.55 x {10^(-4)} * {D^2}
c2 = 0.22 {D^2}
Thus usually c2 is used as the c1 value is small enough to drop out. By using c2 we realize we are dealing with a quadratic situation.
hope this makes sense
-G
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
