Gamma spectrum Na-22: Peak origins
  • Context: Graduate
  • Thread starter Thread starter LucidWaker
    Gamma Peak Spectrum
The discussion focuses on the gamma spectrum of Sodium-22 (Na-22) measured using a Ge-spectrometer with Genie-2000 software. Two significant peaks were identified: 511 keV, attributed to electron-positron annihilation, and 1274 keV, resulting from beta+ decay and electron capture. The peak at 511 keV has a notably higher surface area due to the nature of photon emission during annihilation, despite the directional travel of the photons. The conversation highlights the importance of measuring peak areas and understanding attenuation coefficients in germanium.
  • Understanding of gamma spectroscopy and Ge-spectrometers
  • Familiarity with Genie-2000 software for spectrum analysis
  • Knowledge of nuclear decay processes, specifically beta+ decay and electron-positron annihilation
  • Basic principles of photon attenuation in materials, particularly germanium
  • Research the principles of gamma spectroscopy and its applications in nuclear physics
  • Explore the functionalities of Genie-2000 software for advanced spectrum analysis
  • Study the mechanisms of electron-positron annihilation and its significance in gamma spectroscopy
  • Investigate the impact of attenuation coefficients on gamma-ray detection in different materials
Students and researchers in nuclear physics, radiation detection specialists, and anyone involved in gamma spectroscopy and the analysis of radioactive isotopes.
LucidWaker
Hey,
For my first post here, I had a question about the gamma spectrum of Na-22.
I measured the gamma spectrum of Na-22 with a Ge-spectrometer. Using Genie-2000 software I saw two peaks in the spectrum, 1274 keV (peaksurface 3981±1,74%) and 511 keV (peaksurface 25494±0,68%). (Horizontal axis is divided into channels, each representing an energy band. The vertical axis represents the number of counts)
As an assignment, I have to explain the origins of these peaks and why there is so much difference in peaksurface.
The peak at 511 keV is electron-positron annihilation, I guess. And if I interpret this source* correctly, the peak at 1274 keV is the result of both electron capture (which the assignment wants me to ignore) and beta+ decay?
Another question I had was why the peak at 511 keV is so much higher (a lot more surface)? It is true that electron-positron annihilation yields two photons, but they travel in opposite directions so, in generl, the chance the Ge-spectrometer measures both is quite small. (The sample lies on top of the spectrometer)
Thanks in advance for the help.
*=http://community.middlebury.edu/~PHManual/gamma.html
Look at this plot of attenuation coefficients for photons in germanium:
http://physics.nist.gov/PhysRefData/XrayMassCoef/ElemTab/z32.html
Make sure you are measuring peak areas and not just the counts in the highest channel. In particular look at these attenuation coefficients in germanium.
0.50 MeV 8.212E-02 cm2 per gram
1.25 MeV 5.101E-02 cm2 per gram
Bob S
I hadn't considered this effect before, thanks for bringing it to my attention. I think I can finish my assignment with this.
Thanks again!
  • · Replies 21 ·
9K
