Calculating Pressure in the Stomach after Taking Tums
  • Thread starter Thread starter ngu9997
    Gas Pressure
The discussion focuses on calculating the pressure in the stomach after taking Tums, which produce gas upon reacting with stomach acid. Participants suggest using the ideal gas law (PV=nRT) and discuss the balanced chemical reaction of calcium carbonate with hydrochloric acid. The weight of two Tums is established as 500 mg, leading to the calculation of moles of CO2 produced, estimated at 0.0049 moles. Body temperature is confirmed as 37 degrees Celsius, or 310.15 K, to be used in the pressure calculation. Overall, the conversation emphasizes the necessary steps and equations for solving the problem.
ngu9997
Tums react in your stomach to produce a gas. The average adult stomach expand to one liter when full. Calculate the pressure in the average adult stomach after taking 2 Tums.
Since its asking for pressure, and the volume is given perhaps PV=nRT should be used.
Also P1V1=P2V2 might seem like a possible equation.
I'm honestly not sure how to start this problem. I started with a balanced chemical equation for the reaction of the Tums (CaCO3) and the stomach acid/hydrochloric acid (HCl), which would be:
CaCO3 + 2HCl --> CaCl2 + H2O + CO2. I'm not sure where to go from here or if this is a necessary step in solving the problem. Any suggestions in where to start would be helpful.
Likes Ethan1983
What is the weight of a "tum"?
How much CO2 do you get from the reaction? (In any unit you like)
One tums tablet is 250 mg. So two tums tablets would be 500 mg or .5 grams. If so, then would .0049 moles of CO2 sound correct?
Yes.
What is a body temperature?
37 degrees Celsius. Converted to kelvins it would be 310.15 K. Would I use this as the temperature in the equation PV=nRT?
Sure. I think everything apart from pressure is known now.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
