If we assume 125000 BTUs of energy per gallon at a typical efficiency of 30%, then a gasoline engine can produce about 37,500 BTUs of work for every gallon of gasoline. At $3.00 per gallon, this is 12,500 BTUs of work per dollar
– or 13.2 MJ [Mega Joules] of work per dollar
For electricity, if we assume typical values of 90% efficiency of the electric motors, and 80% efficiency for the batteries, we get about 72% efficiency overall [before the drive train]. Electricity sells for about $0.10 to $0.15 per KW-Hr [depending on where you live], and a KW-Hr is 3.6 MJ, so at 72% efficiency we get about 2.6 MJ of work per KW-Hr of electricity , or 2.6 MJ / ($0.10 to $0.15)...
= 26MJ to 17 MJ of work per dollar.
So it would appear to be as much as twice the expense to burn gas than to run an electric motor - if you only pay 10 cents per KW-Hr for electricity.. If you are paying 3$ for gas and 15 cents per KW-Hr of electric energy, there is only about a 30% price increase going from electric to gasoline - from 17MJ/$ for electric, to 13MJ/$ for gas.
But then you have to factor in the purchase price, lifespan, and the maintenance costs of the vehicle. For example, right now batteries are expensive and they don’t last long. A standard deep cycle lead-acid battery discharged to 50% capacity with each cycle is only expected to last for about 1000 charge cycles. Also, electric cars and hybrids are quite a bit more expensive than gasoline powered cars. So your question is not as simple as it might appear...not to mention the fact that some cars get 40mpg, and some get 10 mpg. In principle the work done per gallon should be about the same for all gas engines, but obviously some cars are implicity more efficient due to their low profile and higher aerodynamic efficiency, more efficient transmissions, etc.
Biodiesel has 118300 BTUs per gallon with a typical efficiency of 40% for diesel engines. Also selling for about $3.00 per gallon, you would get about
- 16.6 MJ of work energy per dollar from your diesel running carbon neutral biodiesel
- about 23% better than gas, but no batteries. And diesel engines are well known for their long lifespan as compared to gas engines.
That was for 100% pure biodiesel. If you are running B20, which will be the most popular blend of biodiesel with regular diesel, you now have 127,259 BTUs per gallon which leads to
- 17.9 MJ of work energy per dollar of fuel, or about 35% more energy than gasoline for the price. So for those paying 15 cents per KW-Hr or more for electricity, it would be cheaper to drive a B20 powered diesel car than to drive an electric car.
Note: 1055 joules = 1 BTU.
Recent news:
...Now Honda is trying to take it back. Its technology of choice: the stinky old diesel engine. Or make that a not-so-stinky new diesel. By 2009, Honda plans to sell "clean diesels" in the U.S. These cars will likely go some 30% farther per gallon than gasoline models. The 2.2CTDi diesel-powered Honda Civic, sold now in Britain, delivers 43 miles per gallon in town and 55.4 mpg in combined city-highway driving. The hybrid Civic manages only 50 mpg in combined driving, while a gas Civic averages 33 mpg. "We're leading the way to cleaner diesel engines," says Honda Chief Executive Takeo Fukui. [continued]
http://www.businessweek.com/magazine/content/06_44/b4007079.htm
