(Gases) How to get dU=(PdV+VdP)/(gamma-1) from U=PV/
  • Thread starter Thread starter InvalidState
    Gases
The discussion centers on understanding the transformation of equation 39.11 into 39.12 in Feynman's lectures. The key point is the application of the product rule in calculus to differentiate the product of pressure (P) and volume (V), leading to the expression dU = (PdV + VdP)/(\gamma-1). The user seeks clarity on how Feynman expands PV into the differential form (PdV + VdP). The explanation confirms that U is a function of both P and V, reinforcing the use of the product rule for differentiation. This highlights the importance of understanding multivariable functions in thermodynamics.
InvalidState
Hello I'm reading Feynman here: http://www.feynmanlectures.caltech.edu/I_39.html
I'm having problems understanding how he turns equation 39.11 into 39.12.
He does some U -> dU trick and he turns:
U=PV/(\gamma-1) into dU=(PdV+VdP)/(\gamma-1)
I don't understand this intuitively. Any help? Specificaly, how he expands PV into that (PdV+VdP) thing.
Without reading the link, seems to me U is function in 2 variables: U=f(P,V)= P⋅V⋅const ⇒ dU=(PdV+VdP)⋅const.
It looks like he is using the product rule for differentiation.
Chet
Ah yes of course! Thanks
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
