The Magic of the Gaussian Function
In summary, the Gaussian function is a widely used probability distribution that takes the general form of f(x) = Ae^\frac{-(x-b)^2}{c^2}. Its antiderivative is the error function erf(x). It is able to describe many real-world phenomena and is closely related to the Binomial distribution and the Central Limit Theorem. This theorem states that the sum of variables drawn from a distribution will approach a Gaussian distribution as the number of variables approaches infinity. However, this only applies to independent and identically distributed samples with finite variance. The Central Limit Theorem is a powerful tool, but it is often oversimplified and misused.
mezarashi
Homework Helper
652
In academics, you hear so much about the Gaussian function, whether it be in statistics, physics, or even social sciences!
The Gaussian function takes the general form of:
[tex] f(x) = Ae^\frac{-(x-b)^2}{c^2}[/tex]
Further yet, the antiderivative of this function is the famous error function erf(x).
What I'd like to know is... what is the magic behind this equation. Why is it able to describe so much real world phenomena. Can it be derived or what was Mr. Gauss thinking when he came up with this.
Is there anything else I missed about the magic of this function?
Mathematics news on Phys.org
The Gaussian probability distribution is closely related to the Binomial distribution such as one finds in the case of a random walk. For example, in one dimension and when the step size is fixed then the distribution is the usual Binomial distribution and, in the limit of a very large number of steps the Gaussian distribution is an excellent approximation to the Binomial. When the step size is not fixed, such as in diffusion, the distribution is Gaussian.
Many physical processes behave like a random walk including diffusion, heat transfer and so on.
Of course, there's also the central limit theorem, which says basically that the sum of variables drawn from a distribution (almost any distribution) will be Gaussian distributed as the number of variables drawn approaches infinity.
The Central Limit Theorem, that SpaceTiger mentions, is remarkable! In any application of mathematics, you have to make SOME assumptions about what kind of "mathematical model" applies. The Central Limit Theory says that, in statistics, we really don't have to worry about that- the Gaussian distribution applies to just about everything!
If we have SOME probability distribution (the only requirement is that the mean, [itex]mu[/itex], and standard deviation,[itex]\sigma[/itex], must be finite) and take n samples from that distribution, then the sum of the samples is a Gaussian (normal) distribution with mean [itex]n\mu[/itex] and standard deviation [itex]\sigma[/itex] and the average of the samples is a Gaussian distribution with mean [itex]\mu[/itex] and standard deviation [itex]\frac{\sigma}{\sqrt{n}}[/itex].
The "normal approximation to the binomial distribution", that Tide mentions, is a special but very important example of that but it applies very generally. If a researcher is looking at people's weights, he can think of each person's weight as a sum of weight's of various parts of the body and surely they will all have the same distribution- almost automatically, he knows that people's weights must be, a least approximately, normally distributed.
Because just about everything can be thought of as the sum of many parts, it follows that almost everything must be, at least approximately normally distributed!
That is indeed a powerful statement from a theory, and also a powerful distribution that can cover it all! Makes me ever amazed at mathematics we have derived to model our physical world.
/me bows to Gauss another 100 times.
Sadly no. It says that when you repeatedly obtain independent samples of the same underlying distribution (iid) and if this underlying distribution has finite variance then the sum/average of these samples approaches in the limit a Gaussian distribution.
There are more distributions with infinite variance around than you might image (e.g. Levy flight), and the condition of iid samples is a tough one, and nobody tells you how many are enough and it applies only to the averge of the sample. The individual samples are still distributed according to the original distribution.
The central limit theorem is a wonderful piece of mathematics, but too often too much simplified and misused.
1. What is the Gaussian function?
The Gaussian function, also known as the Gaussian distribution or the normal distribution, is a mathematical function that is commonly used in statistics and probability theory. It is a bell-shaped curve that describes the distribution of a continuous variable in a population.
2. What are the properties of the Gaussian function?
The Gaussian function has several important properties, including being symmetric about its mean, having a single peak at the mean, and becoming more concentrated as it approaches the mean. It also has a total area under the curve of 1, making it a probability distribution.
3. How is the Gaussian function used in science?
The Gaussian function is used in many different areas of science, including physics, chemistry, biology, and economics. It is commonly used to describe natural phenomena, such as the distribution of particle velocities, the distribution of gene expression levels, and the distribution of stock prices. It is also used in data analysis and modeling to fit data to a normal distribution.
4. What is the relationship between the Gaussian function and standard deviation?
The Gaussian function is characterized by two parameters: the mean and the standard deviation. The standard deviation measures the spread of the data around the mean, and it is used to determine the width of the Gaussian curve. A larger standard deviation results in a wider curve, while a smaller standard deviation results in a narrower curve.
5. Can the Gaussian function be approximated by other functions?
Yes, the Gaussian function can be approximated by other functions, such as the central limit theorem and the Fourier transform. These approximations are useful in simplifying calculations and can be used to describe non-Gaussian distributions. However, the Gaussian function is a very accurate representation of many natural processes and is widely used in scientific research and analysis.
  • Set Theory, Logic, Probability, Statistics
